Dale124 Posted April 10, 2014 #1 Posted April 10, 2014 Hi all I just received a ram gps mount that apparently mounts on the brake or clutch reservoir, but I don't see how. I checked out a YouTube video, but they are mounting to a Suzuki that has a different type of reservoir. They say to remove the screws that hold it on, and replace them with the supplied screws along with the mount. This does not seem do-able on the RSV. Any suggestions or pictures would be most helpful. Thanks Dale
xssquared Posted April 10, 2014 #2 Posted April 10, 2014 I just bought one also, the spacers included are to large but if you grind down one side it may work. I just used the u-bolt that came with mine and put the master cylinder clamp back on.
Bert2006 Posted April 10, 2014 #3 Posted April 10, 2014 Check out this page. If its the unit you have there is a video that explains the install. Sounds like you simply replace the existing screws on your reservoir with the ones provided with the kit http://www.rammount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045066045049056050085/Default.aspx
RedRider Posted April 11, 2014 #4 Posted April 11, 2014 There are two bolts that hold the brake reservoir to the handlebars. Remove those and replace them with the longer screws holding the RAM mount. Works great. Don't do it on the clutch side or the GPS will cover the radio controls. RR
kevin-vic-b.c. Posted April 11, 2014 #5 Posted April 11, 2014 There are two bolts that hold the brake reservoir to the handlebars. Remove those and replace them with the longer screws holding the RAM mount. Works great. Don't do it on the clutch side or the GPS will cover the radio controls. RR just to clarify.... you are saying it sandwiches between the bar and the reservoir not on the lid?
Dale124 Posted April 11, 2014 Author #6 Posted April 11, 2014 There are two bolts that hold the brake reservoir to the handlebars. Remove those and replace them with the longer screws holding the RAM mount. Works great. Don't do it on the clutch side or the GPS will cover the radio controls. RR It doesn't seem to have normal type of bolts. There is no surface to put a wrench on, it's just round and flat! I might just do the handlebar mount if I can't get this off
Dale124 Posted April 11, 2014 Author #7 Posted April 11, 2014 It doesn't seem to have normal type of bolts. There is no surface to put a wrench on, it's just round and flat! I might just do the handlebar mount if I can't get this off Oops. Those were just caps covering the bolts. I see now. I have mounted it further in on the handlebars instead, as it doesn't seem so "in your face" there. I just hope it doesn't slide on the handlebar when traveling. It looks good there though. Dale
Bert2006 Posted April 11, 2014 #8 Posted April 11, 2014 Can you post pictures of what you have so we could see what your holder and your brake reservoir look like??? Would be easier for us to help.
RedRider Posted April 11, 2014 #9 Posted April 11, 2014 Oops. Those were just caps covering the bolts. I see now. I have mounted it further in on the handlebars instead, as it doesn't seem so "in your face" there. I just hope it doesn't slide on the handlebar when traveling. It looks good there though. Dale What GPS? I've had my Zumo 550 there for many years and it does pretty well. RR
alwrmcusn Posted April 11, 2014 #10 Posted April 11, 2014 This is how I have my Ram Mount devices installed on my RSV. They are mounted on top of the clutch and brake reservoirs. They mount with a very short spacer included in the Ram Mount kit (approx. 1/4 inch or less) between the OEM reservoir cover and the Ram Mount. Notice that I made a GPS rain cover from a plastic index card box. I also drilled a small hole thru the cassette deck cover (measure VERY CAREFULLY to ensure proper position) and I drilled a hole thru the side of the rain cover also. I mount my GoPro video on the clutch side mount.
BratmanXj Posted April 11, 2014 #11 Posted April 11, 2014 (edited) http://www.motorcyclelarry.com/index.php?main_page=product_info&cPath=2_119&products_id=8&zenid=djst90qeu7fevnna7v3lkije33 I've been looking at these replacement master-reservoir covers with ram ball mounts but keep choking at spending $80 shipping to outfit both side of the handlebars. Alwrmcusn, do you know the part # for the "over" clutch cover mount that you have? http://www.motorcyclelarry.com/bmz_cache/4/45235aa7c31e3bf43bebc470af89c1e8.image.316x237.JPG Edited April 11, 2014 by BratmanXj
alwrmcusn Posted April 11, 2014 #12 Posted April 11, 2014 That part number is RAM-B-246U It is of course useable on either side of the bike (clutch or brake) Take a look at www.rammount.com
Vedis Posted June 5, 2014 #13 Posted June 5, 2014 There is a less expensive option on Amazon: [ame=http://www.amazon.com/Ram-Mount-RAM-B-346U-Vehicle-Bike/dp/B003CMNXIO/ref=sr_1_1?s=electronics&ie=UTF8&qid=1401930737&sr=1-1&keywords=RAM+BALL+RESERVOIR+COVER]Amazon.com: Vehicle Mount for Bike: Electronics@@AMEPARAM@@http://ecx.images-amazon.com/images/I/41P84NKjduL.@@AMEPARAM@@41P84NKjduL[/ame] This costs less and fits over you reservoir cover so there is no worry about proper seal or leaks.
djh3 Posted June 5, 2014 #14 Posted June 5, 2014 (edited) When he said it bolts up to the clutch resevoir I thought it was one of these dual use types. they come with a rubber bushing sort of thing if you use the U clamp instead of bolting it to the clutch housing. http://www.rammount.com/Gallery/images/RAM-B-309-1U/RAM-B-309-1U.jpg By the way the alwrmcusn- I have oogled your expensive sun screen for the GPS before. Tell me is it mounted with the 2 screws on the back that also mount the GPS holder to the arm? Edited June 5, 2014 by djh3
alwrmcusn Posted June 5, 2014 #15 Posted June 5, 2014 Sorry I have missed your query djh3 until just now. Yes the two screw/bolts (you can see them in the photo) go thru the GPS frame, the index card box sun/rain box and into the diamond shaped gps mount that attaches to the RAM mount arm. Do make sure you align the index card box properly to allow access to the on/off switch on the GPS itself.
djh3 Posted June 7, 2014 #16 Posted June 7, 2014 alwrmcusn: Which GPS? Looks like your mount very similar to mine for a Garmin 765. But which power cable are you using? I use the flat one that goes in the right side lower as your sitting on the bike. Its a bugger to get in and out without that box, so I dont know how I would even get at it to remove power cable.
alwrmcusn Posted June 10, 2014 #17 Posted June 10, 2014 We are currently on vacation. When we get back home I will try to provide photos and more info for you (and anyone else interested) on the "project".
IronMike Posted June 10, 2014 #18 Posted June 10, 2014 I've bought both. Neither got installed. The one that uses the bolts on the clutch or brake side. Comes with weong size bolts. Imagine that. They give you three sizes and none work. So I took the ball out and put it on the passenger floorboard for a GoPro mount. The one that goes over the resivor don't work either in my case something was in the way. So that got filed into the extra parts box. What did work were the standard U bolt ones on the handlebars. Another tip is that the arms that connect come in different lengths so you can get the unit where you want. I found the 3 and 4 inch most useful. I like having the phone and GPS mounted do no wind gets forced into them . (Behind the windscreen) I have a lot of mounts. You would have to see it to believe it.
djh3 Posted June 11, 2014 #19 Posted June 11, 2014 Yea currently my GPS resides on the right hand side in a RAM mount. My plastic e-bay find phone mount has been super for the 5-6yr I have had it and the maybe $20 I spent. I had to glue a rotating swivel it had which was OK as I didnt use it anyways. But I use a velcro to be an extra securing part just incase maybe the grips loosen or something. But a friend had the X mount thing on his Road star last year and it looked like it worked great. Both are mounted behind the windscreen and unless its a gully washer I usually dont fret it.
