Guest black knight
Hi everyone, is there some secret to taking off the bar end weights? I thought I should ask before I twisted with too much force and ended up doing some damage.
Black Knight , all you have to do is remove the small chromed plastic caps at the ends and then you will see were to put an allen key , just unscrew , et voila ,, easy , don't break anything :thumbsup2:
Guest black knight
Thanks, I did take off the end cap and tried all the allen keys in my tool kit and none of them fit, thanks for the help, I will take another look.
Should be an 8mm.
Guest black knight
Well folks, there is no need for an allen key, the end is threaded and they just turn out and off, once I took a good look at the end in some good light I realized that the inside did not have an allen head or any other kind of tooled head, grab and turn, done deal, and as far as the need for tools, I have lots, thanks.
Man I don't want to pee you off but unless you have a Venture that was made in America the end weights have an allen head cut into them. Either that or the rest of us are not riding a RSV 2nd. gen. Glade you got them off ok.
