Does anyone know what the "Mic In" plug is for on the Zumo 660 wiring harness? I need to listen to my Garmin which is what the "Audio Out" connector is for, right? I think it is for use with a cell phone or Bluetooth but I just want to make sure.
Guest tx2sturgis
Plug-in microphone for the sunvisor in a car? For voice commands?
Just guessing.
Microphone from your helmet. Allows you to have your Zumo hard wired to your bike and to talk on the phone over your wired headset/microphone. Buddy Rich cable should work for this, although, I'm not sure. The BR cable was designed for the Zumo 550. Assume it will work with the 600/660. Check with Buddy.
RR
Buddy Rich makes a cable and air rider or someone. I got a used one a fellow bought and never installed. But I have yet to get the Bluetooth part of the mic to work right. If the GPS has Bluetooth you can connect your phone and then use the intercom (somehow I have yet to figure it out or get good directions) I have used mine in a parking lot to call wife but once I got to about 20mph she said there was to much noise. Have not tried it since.
