Danaman Posted March 14, 2014 #1 Posted March 14, 2014 Has anyone had a problem with the gas tank rusting just above the rubber moulding on the back of the tank on the pet cock side. I know of at least three people who have a similar problem. The moulding appears to hold water and subsequently causing the rust problem, just my opinion. Curious to see if this a common problem. It is a 2004 which is always stored in a heated shop and does get washed a lot. I will try to upload a photo.
slowrollwv Posted March 15, 2014 #2 Posted March 15, 2014 I took the molding off my bike when I had it painted and never put it back on.
bongobobny Posted March 15, 2014 #3 Posted March 15, 2014 Mine's been gone for ages replaced with plastic chrome...
Venturous Posted March 15, 2014 #4 Posted March 15, 2014 That would be the lowest part of your gas tank when on side stand. If there was water in the gas it would sink to that point if the bike sat for long periods. I wonder if the maybe the rust isn't coming from inside out...
Danaman Posted March 15, 2014 Author #5 Posted March 15, 2014 Gary that is a possibility that it is coming from the inside. I bought a new tank and will check that out when I replace the tank.
cowpuc Posted March 15, 2014 #6 Posted March 15, 2014 If its not an internal tank issue I wonder if that stuff Brain (Tx2sturgis) told us about this past winter would be a good product to spray in that area... It was an aircraft anti corrostion spray of some kind.. Maybe he will chime in here.. Puc
GeorgeS Posted March 15, 2014 #7 Posted March 15, 2014 My son's 83, CX-500 tank started leaking badly in about the same place. I went to auto parts place, told him about it. He looked up two seperate products for coating the inside of fuel tanks. I ordered one, cost was about $65.00 as I recall. Anyway, it was a two part mix, I followed the directions. And the product coated the complete inside of the tank. It Worked !!! Still not leaking after about 3 years of service. Sorry, don't remember the name of the product.
cowpuc Posted March 15, 2014 #8 Posted March 15, 2014 My son's 83, CX-500 tank started leaking badly in about the same place. I went to auto parts place, told him about it. He looked up two seperate products for coating the inside of fuel tanks. I ordered one, cost was about $65.00 as I recall. Anyway, it was a two part mix, I followed the directions. And the product coated the complete inside of the tank. It Worked !!! Still not leaking after about 3 years of service. Sorry, don't remember the name of the product. Good point George!! I have done lots of tanks thru the years,, I tried the Cream Coat kits, made my own out of a mix of Seal All (GREAT STUFF with many uses) and acetone, tried the electrolisis method (google it, this works really good too) and finally found this stuff called "RED COAT".. The red coat is what a lot of radiator shops use (finally figured it out).. The really nice thing about the red coat is that you dont have to (I still do) acid the tank first.. It literally makes a tank within a tank.. I know of three bikes that I sold many many years ago that the red coat still looks like new in!!
GeorgeS Posted March 15, 2014 #9 Posted March 15, 2014 Good point George!! I have done lots of tanks thru the years,, I tried the Cream Coat kits, made my own out of a mix of Seal All (GREAT STUFF with many uses) and acetone, tried the electrolisis method (google it, this works really good too) and finally found this stuff called "RED COAT".. The red coat is what a lot of radiator shops use (finally figured it out).. The really nice thing about the red coat is that you dont have to (I still do) acid the tank first.. It literally makes a tank within a tank.. I know of three bikes that I sold many many years ago that the red coat still looks like new in!! Well the " Inside " of the CX-500 tank is now a Blue Color . Ha Ha. The stuff dried, and its about a 1/32 inch thick coating inside the complete tank. Also, the stuff takes several days to dry, before you put Fuel into the tank. Anyway, It worked !!! Wish I could remember the name of the product. It was a special order product. Normaly not stocked at auto parts places. If you can't find it, check with NAPA, auto parts.
