SilvrT Posted March 4, 2008 #1 Posted March 4, 2008 Dunno what's going on lately but whenever I play one of those embedded vids, my PC totally freezes. No mouse, no keyboard....nothin. and the vid sounds like a music cd when it's skipping .... anyone else having this problem or know what's causing it? This only started recently.
Kregerdoodle Posted March 4, 2008 #2 Posted March 4, 2008 Sounds like you may have a virus, ok, not you but your PC... run a virus scan, clean your cache, and then see what it will do, what media do you use to open and run the vids?? may need to re-load the software for that also.. Good luck K
Squeeze Posted March 4, 2008 #3 Posted March 4, 2008 I doubt the Virus Theory. Had similiar happening on my brand new and unspoiled VISTA Notebook when opening a Site or a Board with a Lot embedded Videos ... It didn't freeze or lock up, but needed more than 3 Minutes to regain Control. These Videos want to download their starting Point plus some Secinds ahead. So if there are a Lot of Videos, the Bandwith and Speed limits the usage. And maybe the Video Provider limits the outgoing Connections. Guess this is the downside of something quite handy.
Condor Posted March 4, 2008 #4 Posted March 4, 2008 Squeeze said: I doubt the Virus Theory. Had similiar happening on my brand new and unspoiled VISTA Notebook when opening a Site or a Board with a Lot embedded Videos ... It didn't freeze or lock up, but needed more than 3 Minutes to regain Control. These Videos want to download their starting Point plus some Secinds ahead. So if there are a Lot of Videos, the Bandwith and Speed limits the usage. And maybe the Video Provider limits the outgoing Connections. Guess this is the downside of something quite handy. Maybe increase your virtual memory size?? Sounds like you're not able to buffer enough ahead to give the vids an even playback??? I've also found that cleaning out the saved webpage history helps make some room....
Squeeze Posted March 4, 2008 #5 Posted March 4, 2008 Condor said: Maybe increase your virtual memory size?? Sounds like you're not able to buffer enough ahead to give the vids an even playback??? I've also found that cleaning out the saved webpage history helps make some room.... Are you refering to the Swap-File Size ? This Notebook has 2GB of RAM and another 1 GB Swapfile. If that's not enough, i don't what might help. Browser is Firefox. IE7 quit on me with an Error, MS does nothing about it ... UH ... MS ... Maybe they are on Viesta ?? I keep my Mouth shut.
Condor Posted March 4, 2008 #6 Posted March 4, 2008 Squeeze said: Are you refering to the Swap-File Size ? This Notebook has 2GB of RAM and another 1 GB Swapfile. If that's not enough, i don't what might help. Browser is Firefox. IE7 quit on me with an Error, MS does nothing about it ... UH ... MS ... Maybe they are on Viesta ?? I keep my Mouth shut. No Squeeze. Rather than go into a long response, Here's a link that will give you an idea, but basically it increases RAM.
86er Posted March 4, 2008 #8 Posted March 4, 2008 Condor said: Maybe increase your virtual memory size?? Sounds like you're not able to buffer enough ahead to give the vids an even playback??? I've also found that cleaning out the saved webpage history helps make some room.... So how do you increase the virtual memory, Condor? I looked at the Wikipedia link below and didn't see how to increase, just what vitual memory is. :confused24:
Squeeze Posted March 4, 2008 #9 Posted March 4, 2008 Hey thanks for the Link, this is the 'swap File' Size i've meant. On Windows Systems, the File itself is named Pagefile.sys and sits in the Root of the primary active Partition. Since Windows NT 4.0 the Size of the File is managed by System default, which means that the Size changes with the Jobs at Hand, but you can set it to a big fixed size which helps not getting too much Fragmentation on the Hard Drive. First thing i do when installing a new System is to fix this File Size, because Defrag Tool won't move this File Fragments. The earlier you fix this, the more upfront and in Line is this File located on the HD. Now this helps in faster File Transfer. Which leads to a better overall Performance.
Squeeze Posted March 4, 2008 #10 Posted March 4, 2008 86er said: So how do you increase the virtual memory, Condor? I looked at the Wikipedia link below and didn't see how to increase, just what vitual memory is. :confused24: On what System ??
Guest tx2sturgis Posted March 4, 2008 #11 Posted March 4, 2008 This might be too technical, but you may have a loose thingamajig in your frazlenator. Try adjusting the whatzit next to the whatchamacallit. This can be found by removing the hooplascooper bolts and prying off the linkmaters fasteners... This sort of thing is exactly why I switched to a Mac. When windows breaks, it leaves you scratching your head, and the gurus will always say the fix is to reinstall windows. Geeze. http://i62.photobucket.com/albums/h113/tx2sturgis/show/avatar8502_12.gif
86er Posted March 4, 2008 #12 Posted March 4, 2008 tx2sturgis said: This might be too technical, but you may have a loose thingamajig in your frazlenator. Try adjusting the whatzit next to the whatchamacallit. This can be found by removing the hooplascooper bolts and prying off the linkmaters fasteners... That sounds just like everything else in this post to me! Squeeze said: On what System ?? Squeeze, I'm using Windows XP (Pro, I think) on a Gateway Laptop that is about 4 years old. I mainly use Firefox, sometimes I use IE7.
Squeeze Posted March 4, 2008 #13 Posted March 4, 2008 Start/ System Control/ System/ Properties / Extended / System Performance / Extended / virtual Memory / user defined Size/ set both Values to the same Size (minimum half Value of your installed RAM or same Size if your Hard drive has enough free Space on it). I translated this from my German System, the Extended may vary on a English Language Version. I would suggest to change to no Swap file (Size 0) in first Place, then defrag the Drive without Swap File, restart Computer and set the Values as described above. This lead to an unfragmented Swap file somewhere in the middle of the Drive, but better to have the File in the middle than to have it in Portions all over the Drive.
Freebird Posted March 4, 2008 #14 Posted March 4, 2008 I don't think that's your problem. I'm running a 1.86 GHz processor on the notebook with only 1 GB of RAM and they all open and play fine for me. Unless you are running a LOT of stuff in the background, memory shouldn't be the issue. OH...and I'm running Windows XP and Firefox but IE works fine also.
