Brian Posted March 8, 2014 Posted March 8, 2014 I did my first carb sync today. When I was trying to remove the vacuum lines off each side. The nipples came out of the carbs. I tapped them back in and did the sync. The bike runs great now no more hesitation. Do I need to put some kind of sealant arond the nipples? If so what should I use?Thanks
Mike G in SC Posted March 8, 2014 Posted March 8, 2014 (edited) Never thought someone would ask! http://www.rocklube.com/products/items/nipple_cream_main_125x282.gif Couldn't resist. I assume you mean the tube, not the rubber. Saw that done once. I think it will stay on it's own. Edited March 8, 2014 by Mike G in SC
Squidley Posted March 8, 2014 Posted March 8, 2014 You should be fine if you tapped it back into the manifold. They sometimes come out and all I have ever done is exactly what you did, tap them back in gently.
Brian Posted March 9, 2014 Author Posted March 9, 2014 Thanks for the suggestion Mike. I knew I should have used a different description, lol. I'll ask the wife about the nipple cream. I believe the fittings ( nipples ) will stay put. Thanks also Squidley
