Got bike up on new table lift and rear wheel off the deck...spun rear and there seems to be drag...brake caliper has been taken off...how free should rear wheel be? How many turns should be reasonable ..torque on nut is correct
It is difficult to explain excessive drag. You are turning the differential and drive shaft so the wheel will not be 'free wheeling'.
Mike
Mike
...and part of the transmission. It'll be a lot of drag, especially if the oil and gear lube are cold.
