dingy Posted April 1, 2014 Posted April 1, 2014 (edited) Came across a picture of a crank for a Venture on Ebay, I put some arrows at the points on the crank that I mentioned there could be an interference point. Picture the rods attached, piston is at the bottom of its travel, the piston skirts will be in close proximity to the points I highlighted on crank. Gary Edited June 7, 2016 by Freebird
quant55 Posted April 1, 2014 Author Posted April 1, 2014 (edited) I see. I don't have a RSV crank here so I can't do any comparison. It would be nice if the pistons will fit. I tried to look also at different pictures on the internet to compare the pistons and crankshaft from VR and RSV. They actually, from the pictures, looks to be the same. I think maybe they're made from different alloys, not necessarily they have different shapes and sizes. By the other hand, I just located a cheap a crank case that apparently looks good: http://www.ebay.com/itm/191030092943?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Could you please take a look at it and let me know your opinion if this piece worth or not? I tried to ask them for more pictures but maybe due to language barrier (because my technical english is far to be perfect ) I had no success. If you can find out more from them it would be very useful for me. Thank you. I really don't understand what exactly means "fire damage" in their description. I'm seeing the same at another item http://www.ebay.com/itm/89-Yamaha-Venture-Royale-XVZ1300-1300-HEAD-CYLINDER-VALVE-SET-/310754306651?pt=Motorcycles_Parts_Accessories&hash=item485a666a5b and wires from the coils melted in another picture: http://www.ebay.com/itm/89-Yamaha-Venture-Royale-XVZ1300-1300-COILS-COIL-/190910692099?pt=Motorcycles_Parts_Accessories&hash=item2c7329fb03 but it is not clear to me if there is something wrong with the crankcase. Edited April 1, 2014 by quant55
quant55 Posted April 15, 2014 Author Posted April 15, 2014 Ok, the crank case just arrived. Some painting needed but else is in excellent condition. I hope this time everything will go fine with the engine.
Freebird Posted June 7, 2016 Posted June 7, 2016 I have uploaded most of the pictures. Not 100% sure if I got them all correct but it should be most of them.
