Hi all,
Has anyone used the Ram Mount X-Grip? I had one ordered and then found a few reviews that said it rotated pretty freely around the axis where the arms attached - not at the ball itself. Cancelled my order... but it's what I want... :(
Soooo. any opinions? or were the reviewers mistaken? bad installs etc...
http://www.amazon.com/RAM-Universal-X-Grip-Holder-1-Inch/product-reviews/B0055PH0XA/ref=dp_top_cm_cr_acr_txt?showViewpoints=1
TIA
I read a lot of those reviews & most had no issues. Sounds to me as though the ones who did have an issue may not have adjusted it tightly enough. If I were you, I'd go for it, since you did say it's what you want. :2cents:
I've been using one for about a year now. I have no issues at all with the product. It does rotate a bit, I wouldn't exactly call it freely. I find it stays where I put it. I also use it for my GPS. I would definitely purchase another if mine went missing.
Guest tx2sturgis
You gonna hang an expensive smartphone in that? On a motorcycle?
I think its designed for cars...
Maybe your phone or GPS or whatever has a RAM cradle made specifically for it. If so, thats the one I would use. If not, this RAM mount is the bees knees:
[ame]
[/ame]
:happy34:
:happy34:
I agree, hmmmm.... you might be changing my mind, but I'm pretty sure that bottom piece would block the audio out plug that I would use to go to the aux. input on the state of the art cassette deck. Maybe I can cut it a bit.....
Thanks for the input.... back to the drawing board!
On the Universal Finger Grip shown in the video, it just shows the phone holder and not how it'd attach to the bike.
I'd like to attach a smart phone to my new to me 06 RSV.
What's the best way to mount such a holder...???:cool10:
If you go to the Ram mount page, scroll to the bottom and you will see their suggestions. I'm new to this system too, but with a little bit of research you can find something that will suit your needs.
Check these out: http://www.rammount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045066045050051056085/Default.aspx
http://www.rammount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045066045050048049085/Default.aspx
http://www.rammount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045072079076045085078052085/Default.aspx
I'm doing some shopping on Amazon... just sayin'
Edited by Mad Dog
Guest tx2sturgis
The RAM system is modular, so you order the parts you need for what your trying to do...so if you order the universal grip, a RAM ball for it, then a 3 or 4 inch arm and RAM ball mount for your handlebars, you're all set.
http://www.rammount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045066045049052057090045085078052085/Default.aspx
I use that exact piece in my semi (with a windshield suction mount) and its VERY sturdy....assuming your device will fit in it, (measure it!) you wont lose it from the mount!
Edited by tx2sturgis
Guest tx2sturgis
The bottom and top U-shaped pieces wont block the port if its in the middle of the bottom or top edge. It might block the port if its offset..but as you said, maybe you could modify the mount slightly. Depending on the size of the device, you might be able to offset the grip 'fingers' so that you get the clearance you need.
:think:
:think:
Yeah... its an iPhone, so the power is in the middle bottom and the audio plug is on the left bottom, about halfway between the corner and the power port. I cut the holder I use in my car (different brand - junk actually) and it's fine. This will be even better.
Thanks
Guest tx2sturgis
Thanks
RAM makes iPhone mounts, but the ones I have seen dont work well with a case like an otterbox or whatever kind you might be using.
If the case is not too large, the universal mount should work fine. It works on my Nexus 5 with a case, and that phone is already a bit larger than the iPhone.
The X-Grip just looks too flimsy. And it seems to leave the phone likely to slip out on rough roads. But then they DO warn you to use some sort of security lanyard with any of the mounts. You wont need it with the universal grip. Its a good one.
:happy34:
:happy34:
Thanks! & Ordered!
$19 for the holder and $7 for the ball mount for the back of the holder. I already have an arm and u-bolt mount
Guest tx2sturgis
Thanks! & Ordered!
Cool....so when you get it all mounted and test it, how about posting a short review?
Lots of riders want to take their smartphones along for the ride now.
:happy34:
:happy34:
I suppose I would owe at least that to you guys... along with the $12 fee!
I haven't even picked up my Venture yet (4/5 is the date unless it warms up sooner) and this board has helped me a ton!
As I think I mentioned above I wrote to Ram Mount to ask about this. I thought I'd share their reply. Thanks to all who helped me out!
Hi Mike,
Thanks for your e-mail. Unfortunately, this review is true and, no, we have not updated the design since it was made. The reason these mounts rotate is that the X-Grip mounts are universal and designed to hold a device larger than the one the reviewer is using. In other words, the closer to the maximum width of the X-Grip your device is, the less it will rotate. We have explored solutions for this, however, most would limit the universality of the mount or be prohibitively expensive. We have come up with a fix that works quite well; however, its not the most elegant solutions: if you break off a section of Popsicle stick slightly shorter than the distance the arms of the X-Grip rotate and place this section between one arm and the body of the X-Grip you can limit the movement of the arms and eliminate the rotation issue.
Thanks for your interest in RAM Mounts and please let me know if there are any other questions I can help with.
Best regards,
Reid Mortimer
National Products, Inc | RAM Mounting Systems
Guest tx2sturgis
Popsicle stick?
So we're supposed to go buy a package of popsicles?
:rotfl:
The guy should have directed you to another RAM mounting solution, not the freezer section at your local grocery!
Jeeze. Hopefully that is a new guy, and I can tell you the RAM stuff is good, even if the rep doesnt know much about it.
:happy34:
  • 4 weeks later...
I have been using the RAM X Grip for a couple years with no issues. There is just a little play in the rotation after you snap your device into it. I would say less than 10 degrees but while riding I've not seen it move even when riding rough roads.
