Lotus Motorcycle
Freebird
From a 2 cylinder yet
Engine
Construction: 2-cylinder 4-stroke engine, 75° V-style
Capacity: 1,195 cm³
Bore: 105 mm
Stroke: 69 mm
Power Approx: 200 HP
Transmission: 6-gear jaw-type shift transmission
Lubrication: Dry sump lubrication
Main shaft ratio: 40:76
Lay shaft ratio: 15:41
Clutch: Hydraulic anti-hopping clutch
Ignition: Full electronic engine management with digital adjustment of the ignition
BMW S 1000 RR
Type Water/oil-cooled 4-cylinder 4-stroke in-line engine, four titanium valves per cylinder, two overhead camshafts
Bore x stroke 80 mm x 49.7 mm
Capacity 999 cc
Rated output 193 hp (142 kW) at 13.000 rpm
http://www.bmwmotorcycles.com/_common/img/bikes/sport/2013/s1000rr/s1000rr_racing_red_white3_lead_184x124.jpg
I have to agree with Don. It might be fun for a couple of minutes.
With the bore and stroke that it has, it must be a very high revving engine.
with as close as the foot pegs are to the seats, you would have to break both of my legs and maybe a few other parts to get me on it.
