Donvito Posted February 16, 2014 #1 Posted February 16, 2014 Now that all my major problems are fixed with your help, I thought I would try to get my intercom working again. I have an 87 VR with two 20 plus year old J & M headsets. Both headsets ear phones work and music from the radio or cassette works fine. Only the intercom doesn't work. I have tried switching them to the other plug with no help. Because both sets of earphones work, I am assuming it isn't a problem with the headsets but I may be wrong. Anyone have any advice? I have had both top fairing top covers off recently to replace the speakers which work fine also so not sure if I could have dislodged something. Thanks.
Trader Posted February 16, 2014 #2 Posted February 16, 2014 First thought would be try a different headset. It's possible both sets you have have bad microphones
dacheedah Posted February 16, 2014 #3 Posted February 16, 2014 Doesn't the first gen have a mute button? stuck switch maybe
mbrood Posted February 16, 2014 #4 Posted February 16, 2014 The Intercom volume knob can be turned OFF (full CCW) or to the desired sensitivity, it sounds like it's not ON, loud enough or there's a problem with that unit. http://www.bergall.org/temp/venture/vr1.jpg
Prairiehammer Posted February 16, 2014 #5 Posted February 16, 2014 Adjust the "H-PH ATT" knob on the audio remote control box on the left handlebar AND the passenger remote control H-PH ATT knob.
mbrood Posted February 16, 2014 #6 Posted February 16, 2014 Kevin, I believe those control only the headphone speakers, the intercom (mic) volume is only selected by the driver on the radio control panel. Mike
Donvito Posted February 16, 2014 Author #7 Posted February 16, 2014 Doesn't the first gen have a mute button? stuck switch maybe Thanks for the advice I wouldn't have thought of that. Unfortunately, the mute buttons are off and do work to mute the radio through the earphones. Good advice though.
MiCarl Posted February 16, 2014 #8 Posted February 16, 2014 Kevin, I believe those control only the headphone speakers, the intercom (mic) volume is only selected by the driver on the radio control panel. Mike Not quite. The rider controls the maximum volume of all the sources. The ATT knobs allow either the rider or passenger to reduce individual headset volume from those levels.
MiCarl Posted February 16, 2014 #9 Posted February 16, 2014 The mute button doesn't affect the intercom, only the other sources.
Donvito Posted February 16, 2014 Author #10 Posted February 16, 2014 The Intercom volume knob can be turned OFF (full CCW) or to the desired sensitivity, it sounds like it's not ON, loud enough or there's a problem with that unit. http://www.bergall.org/temp/venture/vr1.jpg Thanks for the advice. When I adjust the volume with the radio off, I can hear a hum through the headsets which gets louder as I adjust it. BTW the CB also works through the earphones. The music will turn off when I adjust the squelch like it should.
Donvito Posted February 16, 2014 Author #11 Posted February 16, 2014 Maybe it is the microphones. I don't see a way to open the casing to get to the microphones. I'll try to find someone with working headsets. Anyone in Florida with a set? Are any other bikes compatible with our system? Thanks.
cimmer Posted February 17, 2014 #12 Posted February 17, 2014 Just asking a dumb question here but dont you have to push the push to talk (PTT) button for the mics to work. I believe the drivers is on the other side of the of the left hand controls facing the front of the bike and the riders is on the remote control unit. You hadnt mention pushing these and thought I would just throw it out there. Hope you get it working, Rick F.
dacheedah Posted February 17, 2014 #13 Posted February 17, 2014 no ptt, I remember an intermittent mic issue with my 89, it was the front chord had been pinched.
Prairiehammer Posted February 17, 2014 #14 Posted February 17, 2014 Just asking a dumb question here but dont you have to push the push to talk (PTT) button for the mics to work. I believe the drivers is on the other side of the of the left hand controls facing the front of the bike and the riders is on the remote control unit. You hadnt mention pushing these and thought I would just throw it out there. Hope you get it working, Rick F. No, adjusted properly, the First Gen intercom utilizes a VOX (voice activated) microphone. Simply speak, and the passenger and operator microphones are activated. A nice plus for the First Gen over the second Generation. You do have to use the PTT button to speak on the CB.
dacheedah Posted February 17, 2014 #15 Posted February 17, 2014 The mute button doesn't affect the intercom, only the other sources. It does mute the IC, I was in a disagreement with the back seat passenger, I got my say and muted her, then I got my say again. . . I paid for it later
dacheedah Posted February 17, 2014 #16 Posted February 17, 2014 Are you sure that the po didn't install mic mutes on it? Try hitting the TX button for the cb and talking ( with the cb off). Another thought
Donvito Posted February 17, 2014 Author #17 Posted February 17, 2014 no ptt, I remember an intermittent mic issue with my 89, it was the front chord had been pinched. Can you tell me where the cord is located? Thanks.
Donvito Posted February 17, 2014 Author #18 Posted February 17, 2014 Are you sure that the po didn't install mic mutes on it? Try hitting the TX button for the cb and talking ( with the cb off). Another thought I am the original owner. Thanks for the suggestion but that didn't work.
cimmer Posted February 20, 2014 #19 Posted February 20, 2014 Sorry about the PTT button, but I was looking in the service manual and it talks about the noise sensing microphone. It is located on the amplifier controller to the right of the AUTO knob. Could this be your issue? It might be defective and not letting the intercom function properly or is it covered with something, that is not letting it work properly. I am reading in the service manual on pages 7-105 and 7-106 if that helps you any. I would also try using the mic with the CB just to make sure the mics are working properly. You should be able to find someone to give you a check when you transmit out.. Hope that helps some.. Good luck Rick F.
dacheedah Posted February 20, 2014 #20 Posted February 20, 2014 Sorry about the PTT button, but I was looking in the service manual and it talks about the noise sensing microphone. It is located on the amplifier controller to the right of the AUTO knob. Could this be your issue? It might be defective and not letting the intercom function properly or is it covered with something, that is not letting it work properly. I am reading in the service manual on pages 7-105 and 7-106 if that helps you any. I would also try using the mic with the CB just to make sure the mics are working properly. You should be able to find someone to give you a check when you transmit out.. Hope that helps some.. Good luck Rick F. I believe that adjusts for road noise
