Marcarl Posted June 14, 2011 Posted June 14, 2011 There's simply no "simple" way around it ... There is actually,,,,, but you won't be able to understand that unless you pull the engine 3 times in a row to get it done,,,,,,, it's at that point that the 'first time right' would have been much simpler.
frankd Posted June 15, 2011 Posted June 15, 2011 Well, I don't have a shade tree method for setting the gear lash, but I do have one for replacing the seal. It's been quite a while so pardon me if I don't picture this job in my mind quite correctly. I had a middle gear seal leak that I was tired of, and I didn't want to have to reset the gear lash. I marked the nut and shaft (with punch marks or with a Dremmel tool) so that I could return to the same exact place. Then I carefully counted how many turns it took to get the nut off (I seem to remember 13 1/2 turns), replaced the seal, and then put it all back together and turned the nut 13 turns and then to the mark. It worked great. Frank D.
