baylensman Posted January 26, 2014 Posted January 26, 2014 need to tear into this tomorrow early hope some one is on with and answer. 96 RSTD my son blew a radiator hose (he thinks) on his way to Gasparilla tonight. Looking at the diagram all the hose look as if they are the same diameter at either end, so I can probably fix with bulk hose at local parts store right? Any thoughts on what sizes? 5/8 3/4 metric?
djh3 Posted January 26, 2014 Posted January 26, 2014 I just had my RSV apart to do the valve check and hoses disconnected. I would say 3/4. but your best bet is to find the leak and pull that hose to be sure.. Depending on which hose it could be a few minute job or a bit more time.
baylensman Posted January 27, 2014 Author Posted January 27, 2014 Fot it done (well made the kid do it) hose split just above clamp where it goes into cylinder head,
djh3 Posted January 28, 2014 Posted January 28, 2014 Right side rear? I think that was a molded type hose. Glad you all got it fixed.
baylensman Posted January 28, 2014 Author Posted January 28, 2014 Right side rear? I think that was a molded type hose. Glad you all got it fixed. no its almost dead center of front head a little more to the left than actual center, turns out he poked a screw driver thru the new one getting the clamp seated so he had do do it all again, That'll learn the young in
