how well do you know your motorcycles
hell yea
  • Replies 1.3k
  • Created
  • Last Reply
Top Posters In This Topic
1962 Prototype Junak M14 Iskra
technical characteristics according to the documentation
engine designed: four-stroke , OHV OHC , twin-cylinder, in-line , spark ignition, air cooled,
Displacement: 350 cm ³
Bore: 62 mm Stroke: 58 mm
compression ratio: 8,5:1 - 9:1
Max Power: 21 hp / 6,000 rpm. / min - 26 KM/7000 rev. / min.
maximum torque of 32 Nm at 3200 to 4200 rpm. / min.
clutch: cztero tarczowe, wet, spring center
Transmission: four-
powertrain weight around 47 kg
brakes: mechanical drum, pełnopiastowe
Front suspension: swingarm pushed with hydraulic telescopic shock absorbers
Rear Suspension: Trailing arm with hydraulic telescopic shock absorbers
weight: 140 kg
Baku capacity: 13 l
Maximum speed: 140 km / h (design)
it is a Triumph but it is using the Rocket 3 motor. The Triumph motors were straight up and the Rocket 3 motors had the forward cant. Must be about a 74 or 75. Love the use of the original tank.
It is a 1975 Triumph Quadrant four, 1000cc. A factory prototype. http://www.venturerider.org/forum/showthread.php?t=83997&page=13
Try to keep up, Paul.
Just kidding. It was solved yesterday morning.
:whistling::backinmyday:
1962 or 63 Norton Electra 400 cc a baby Atlas.
By Golly! You are correct!
http://www.nortonownersclub.org/models/light-twins/lightweight-images/0093.jpghttp://www.nationalmotorcyclemuseum.co.uk/museum/exhibits/bikes/fullsize/norton-electra.jpghttp://www.ridermagazine.com/wp-content/uploads/2013/03/web-Retro-1-Norton.jpg
Originally for export only when launched in 1963, the Electra was Norton’s first motorcycle to offer electric starting and carry flashing indicators as original equipment. A revvy overhead valve short-stroke twin developed from the earlier 250cc Jubilee and 350cc Navigator, the 383cc Electra has a Lucas starter motor sited behind the cylinders and driving the crankshaft by chain. Despite its modernity, the Electra was not a success: its shortcomings included unreliable starting, engine vibration and heavy fuel consumption. Norton, whose entire production was moved to Associated Motor Cycle’s London plant in 1963, dropped the model after two years.
