mralex714 Posted January 17, 2014 #1 Posted January 17, 2014 I got my bike back from the shop and rode home. When I picked it up the aftermarket radio didn't work. Once I got home I tried to run down the problem with no success. While trying to get the radio going I noticed that the emergency flasher also didn't work. I changed the fuses with no luck. After I changed those fuses the bike wouldn't start. I turned on the key no fuel pump click, push the start button and no starter crank, kill switch is in correct position. Any ideas on what my problem might be?
utadventure Posted January 17, 2014 #2 Posted January 17, 2014 Do you still have the original fuse block in your '86? Check the power voltage on both sides of the fuses at the wires, not the holders. The holders weaken and break over time and you may not be getting full power through the block. Dave
Prairiehammer Posted January 17, 2014 #3 Posted January 17, 2014 Do you still have the original fuse block in your '86? Check the power voltage on both sides of the fuses at the wires, not the holders. The holders weaken and break over time and you may not be getting full power through the block. Dave My first thought. You changed fuses and then stuff happened. Also check the kick stand switch.
mralex714 Posted January 18, 2014 Author #4 Posted January 18, 2014 Do you still have the original fuse block in your '86? Check the power voltage on both sides of the fuses at the wires, not the holders. The holders weaken and break over time and you may not be getting full power through the block. Dave Fuse block has been updated.
utadventure Posted January 18, 2014 #5 Posted January 18, 2014 Fuse block has been updated. I'm glad you have the upgraded fuse block. This is still the diagnostic point I would start at. If power is not getting to or through the block, you've narrowed the search area. If it is, then you can start to trace it out.
Flyinfool Posted January 18, 2014 #6 Posted January 18, 2014 You have to start at the beginning. What is the battery voltage with the ignition off? Battery voltage with ignition on?
mralex714 Posted January 18, 2014 Author #7 Posted January 18, 2014 You have to start at the beginning. What is the battery voltage with the ignition off? Battery voltage with ignition on? Voltage is 12.6 with the key off, the stator is new and the bike started prior to changing those fuses. Everything comes on all the lights work, the horn blows.
Marcarl Posted January 18, 2014 #8 Posted January 18, 2014 Check to make sure the ground wire is properly hooked at the battery, that the wire is crimped tight and that is is clean and tight on the engine, right by the water pump.
mralex714 Posted January 18, 2014 Author #9 Posted January 18, 2014 Wire to the ignition fuse pulled loose. I repaired this and got the bike started. I figured out the problem with the radio. The hot wire that keeps setting has no power. I'm guessing this the common problem with the hazard flasher any thoughts. Started getting cold so I quit for the day
mralex714 Posted January 20, 2014 Author #10 Posted January 20, 2014 Wire to the ignition fuse pulled loose. I repaired this and got the bike started. I figured out the problem with the radio. The hot wire that keeps setting has no power. I'm guessing this the common problem with the hazard flasher any thoughts. Started getting cold so I quit for the day Anyone?
utadventure Posted January 20, 2014 #11 Posted January 20, 2014 Have you checked the other fuses? There is a second set of fuses tucked up behind the battery. The constant power for the audio system may go through it.
SpencerPJ Posted January 24, 2014 #12 Posted January 24, 2014 Did you bump the kill switch, been there, done that.:whistling:
mralex714 Posted January 24, 2014 Author #13 Posted January 24, 2014 Have you checked the other fuses? There is a second set of fuses tucked up behind the battery. The constant power for the audio system may go through it. I checked those fuses and they were good, also there is power at the fuse block.
jasonm. Posted January 25, 2014 #14 Posted January 25, 2014 something for the future...I see you replaced the fuse block. Many of us have done this, good. but i soldered the wires at the block and sealed with RTV silicone. RTV acts as a strain relief and sealer from corrosion. Simply sounds like you service guy did not check his work. You will need a VOM to check what's connected or not connected. Ask yourself, what area did the service guy have his hands into the bike ?
