BratmanXj Posted January 15, 2014 #1 Posted January 15, 2014 (edited) Collecting parts to star my winter modifications come the start of February. So far I've picked up new steering head bearing because the previous owner had them SO loose when I purchase that the front end would chatter. I've tightened them up but you can feel a noticeable "flat spot" at center. I understand what needs to be done, but looking to see if there is a checklist or photo-instructions on everything that needs to come apart on a '99 RSV. Thanks Edited January 15, 2014 by BratmanXj
kevin-vic-b.c. Posted January 15, 2014 #2 Posted January 15, 2014 that is info that I will save if it comes out.... good question.
aharbi Posted January 17, 2014 #3 Posted January 17, 2014 I know they exist, I've used them. Very well written as I recall. Just have to figure out where I found them. I did print them out and have them in the service manual. sent from my Nook HD+
djh3 Posted January 17, 2014 #4 Posted January 17, 2014 Hmm I remember reading somewhere about the disassembly procedure also. I found a drwing, but thats not any real help to you. I bet it aint going to be fun though.
vzuden Posted January 18, 2014 #5 Posted January 18, 2014 I've done this a couple of times. The first time was a few years ago and I found a step by step description on this site. I have been searching and not found it but I am using my phone - will try later. Plan on a full day for your first time. I lay out an old blanket on the floor and place the parts on it in order of removal. It helps to take pictures of everything as you disassemble - especially cable routing.
sleadhed Posted January 27, 2014 #6 Posted January 27, 2014 I just pulled the front end down on my RSV Saturday. Just take your time. It helps to bag up screws and mark them. Take pictures and notes of the wire, cable and hose routing. It can look over whelming but it realy is not as bad as it looks. Ken
Ventureless Posted January 27, 2014 #7 Posted January 27, 2014 I just pulled the front end down on my RSV Saturday. Just take your time. It helps to bag up screws and mark them. Take pictures and notes of the wire, cable and hose routing. It can look over whelming but it realy is not as bad as it looks. Ken Overwhelming is not the word. I started doing mine at one point and after a couple hours and seeming to get no where, I put it all back together and decided that since I can pretty much do anything else on the bike by myself, why not go ahead and pay someone to do the steering bearings. It was just not going to be worth the frustration I would have put myself through. I know a lot of guys do it on their own, but not this guy. Good thing mine were not bad and turned out they really didn't need to be done at the time. So if someone wants to make some extra cash, let me know and I will give you a call when they need to be changed.
Seaking Posted January 29, 2014 #8 Posted January 29, 2014 Somewhere lies the tutorial on how to change out the bearings where you 'suspend' the front fairing unit so that you don't have to disconnect everything (this is where most people get frustrated with trying to get it all together again). Unbolting the fairing frame, and pulling it all away from the bike as it hangs from the sky hook.. You gain just enough room to get access to get the job done, and saves you a lot of time and effort. Haven't been able to find that tutorial but it's out there, with pics and descriptions..
VegasVic Posted January 30, 2014 #9 Posted January 30, 2014 I spent 3 & a half hours today tearing the fairing apart to inspect and hopefully only grease my steering head bearings. Not fun. Will probably take a couple hours longer to put back together. I just used the pics in my service manual.
djh3 Posted January 30, 2014 #10 Posted January 30, 2014 Grrr ya know now that someone mentioned it in this post I do remember seeing a post somewhere and the guy had the bike front end hanging from a sling to the rafters. Now if he was doing steering bearings I dont remeber but I think so. I tend to belive if you could suport the front of the bike, take the handlebars out of the risers and lower the stem out you wouldnt have to disconnect all the cables and lines. Probably still have to discombobulate the fairing inner though. Hmmm Back to the search.
ragtop69gs Posted January 30, 2014 #11 Posted January 30, 2014 HERE is a link that gets you down to the trees. HERE is a drawing of the steering head assembly.
