baylensman Posted January 11, 2014 Posted January 11, 2014 i'll try again as it seems no one understood what i was asking. on a 96 standard the igntion switch is located on the right side under the seat. having pulled the seat, the battery, the battery cover, and the lower plastic sheild where the passenger foot peg mounts, it is still a bear to get at, what am I missing or is this really that poorly designed? Second, where can i get a new switch? can I use my old tumbler? third is it the switch that is the problem or the tumbler? sometimes the key won't turn or release from the switch other times it seems that the key turns but is not doing anything inside (turns to easy) P.S. this is my old bike which I gifted to my son when i got my 07RSV
eusa1 Posted January 11, 2014 Posted January 11, 2014 Text me direct, or call and i will answer your questions 815-440-0287 mike
M61A1MECH Posted January 11, 2014 Posted January 11, 2014 on a 96 standard the igntion switch is located on the right side under the seat. having pulled the seat, the battery, the battery cover, and the lower plastic sheild where the passenger foot peg mounts, it is still a bear to get at, what am I missing or is this really that poorly designed? Yes it is that poorly designed, unfornuatley the place they relocated the switch to on later models was just as bad, on the frame right behind the radiator, where they got fried from the heat. Second, where can i get a new switch? can I use my old tumbler? I am not sure about a "NEW" switch, the only place is probably a dealer if you need new. If you just want another, then Ebay some place like Pinwall, they generally have a good selection of such things. Should be able to change the tumblers out, had it done by the dealer under warrenty on my 98 Tour Cllassic when the ignition switch went out. third is it the switch that is the problem or the tumbler? sometimes the key won't turn or release from the switch other times it seems that the key turns but is not doing anything inside (turns to easy) That is not clear, but I would suspect it is the mechanics inside the tumbler and the drive rod that engages into the electrical switch, could be something came loose or fell out. You will need to get it out and dissassemble it to know.
M61A1MECH Posted January 11, 2014 Posted January 11, 2014 Use this link to get to the classified section, I think this is the same switch you want. http://www.venturerider.org/classifieds/showproduct.php?product=4882&title=new-key-switch-for-royal-star-&cat=8
