Bert2006 Posted January 11, 2014 Posted January 11, 2014 Has anyone tried to fit the Truck-Lite 4.5 LED lamps in the stock passing lamp buckets on a 2nd gen? I am talking about the ones that match their Phase 7 headlamp units? I just need to know if they fit in the buckets. Thanks. Here is a link to the ones I am looking at. http://www.truck-lite.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=92029&langId=-1
Squidley Posted January 11, 2014 Posted January 11, 2014 The measurements posted look good to me, the pigtail will wrap inside the bucket...go for it and let us know what you think of them
RedRider Posted January 11, 2014 Posted January 11, 2014 (edited) The standard bulb size is PAR36. It looks close to what these are. Not sure on depth. This is a setup I am looking at. Should drown out the headlight. Although they are a little expensive. Hit the 'Data Sheet' link on the right side of the page for more info. 900 lumens each. http://www.waytekwire.com/item/47738/TRILLIANT-LED-PAR-36-WORK-LAMP/ RR Edited January 14, 2014 by RedRider
Bert2006 Posted January 11, 2014 Author Posted January 11, 2014 The depth is what I am concerned about. They seem to have a squared off back as opposed to the more rounded profile of par 36 lamps.
wes0778 Posted January 11, 2014 Posted January 11, 2014 Has anyone tried to fit the Truck-Lite 4.5 LED lamps in the stock passing lamp buckets on a 2nd gen? I am talking about the ones that match their Phase 7 headlamp units? I just need to know if they fit in the buckets. Thanks. Here is a link to the ones I am looking at. http://www.truck-lite.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=92029&langId=-1 Did I miss it? Don't see where it mentions price or lumens
Bert2006 Posted January 11, 2014 Author Posted January 11, 2014 Did I miss it? Don't see where it mentions price or lumens Its says 280 lms when you scrool down on this page. Also has price http://www.headlightrevolution.com/Truck_Lite_s/1848.htm
wes0778 Posted January 12, 2014 Posted January 12, 2014 (edited) Its says 280 lms when you scrool down on this page. Also has price http://www.headlightrevolution.com/Truck_Lite_s/1848.htm This might be a better deal, 500 Lumens. http://www.ebay.com/itm/One-Truck-Lite-80240-LED-PAR-36-Driving-Passing-Lamp-Light-Motorcycle-Connector-/181241926229 Or This, but lumens unknown... http://www.ebay.com/itm/TRUCK-LITE-HIGH-INTENSITY-PHASE-7-LED-MOTORCYCLE-PASSING-LAMPS-4-1-2-2247-PAIR/121183155603?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D19839%26meid%3D4058757562709746251%26pid%3D100005%26prg%3D8934%26rk%3D1%26rkt%3D5%26sd%3D181241926229%26 Edited January 12, 2014 by wes0778
Bert2006 Posted January 12, 2014 Author Posted January 12, 2014 This might be a better deal, 500 Lumens. http://www.ebay.com/itm/One-Truck-Lite-80240-LED-PAR-36-Driving-Passing-Lamp-Light-Motorcycle-Connector-/181241926229 Or This, but lumens unknown... http://www.ebay.com/itm/TRUCK-LITE-HIGH-INTENSITY-PHASE-7-LED-MOTORCYCLE-PASSING-LAMPS-4-1-2-2247-PAIR/121183155603?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D19839%26meid%3D4058757562709746251%26pid%3D100005%26prg%3D8934%26rk%3D1%26rkt%3D5%26sd%3D181241926229%26 The first one is more of a flood light so would probably offend other drivers while the second one is the same one I am asking about. PHASE 7 is made by Truck-Lite. Looks like it is a 280 lumens. GE Par 36 are 300lmns for the 13w sealed beam units.
Seaking Posted January 12, 2014 Posted January 12, 2014 Something to take into consideration with LED lights is if they cause interference with your radio.. Earlier units caused a lot of interference, while the ones I got from Customdynamics do not.. expensive but at least they work well.. solid! Best of luck, looking forward to see if these work out for you. Cheers
Bert2006 Posted January 13, 2014 Author Posted January 13, 2014 Well, I ordered them today . This will be the last purchase for a while as I have been :mo money:like crazy on the bike in the past few months. Will let you know how they fit once I have them on. This is what they are and where I got them. Not cheap but best price I found so far. http://www.ebay.com/itm/TRUCK-LITE-HIGH-INTENSITY-PHASE-7-LED-MOTORCYCLE-PASSING-LAMPS-4-1-2-2247-PAIR/121183155603?rt=nc&_trksid=p2047675.m1851=&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D19839%26meid%3D4058757562709746251%26pid%3D100005%26prg%3D8934%26rk%3D1%26rkt%3D5%26sd%3D181241926229%26=
bill4you502 Posted March 30, 2014 Posted March 30, 2014 Has anyone tried to fit the Truck-Lite 4.5 LED lamps in the stock passing lamp buckets on a 2nd gen? I am talking about the ones that match their Phase 7 headlamp units? I just need to know if they fit in the buckets. Thanks. Here is a link to the ones I am looking at. http://www.truck-lite.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=92029&langId=-1 Anyone know of any "Bright White" seal beams that will fit the OEM passing light shells????
