dna9656 Posted December 20, 2013 Posted December 20, 2013 (edited) I get a E-4 error code (no signal from the pressure sensor) when checking the CLASS suspension system. The part isn't available, apparently it came with the valves; not alone. Am I goig to find one? Is there a work around for this? Your input would be helpful! Is there a functional test for the sensor to rule it out as the problem? I know if I rule out the connections between the computer and the sensor pig tail and it still gives me "E-4" it could be the sensor or the computer....I have another sensor and computer in the 85, prob. won't work on a 83 though....right? Edited December 20, 2013 by dna9656 more questions
Prairiehammer Posted December 20, 2013 Posted December 20, 2013 Doug, the "E4" error is most commonly associated with cold solder connections on the controller board. See this Tech Bulletin: Also, the controller from the '85 should be the same as the controller on the '83.
