DarrinGT Posted December 10, 2013 Posted December 10, 2013 For some reason I cant see my sent PM's My Inbox shows up no problem but I have nothing in the "Sent" folder. I have a couple that I sent out last week and wanted to re read them but cant find them, Am I doing something wrong or is that just how it is set up?
Black Owl Posted December 10, 2013 Posted December 10, 2013 Click user CP on in the box on the left side of the screen. On the screen that pops up, scroll down to the block for messages. In that block you will see a choice to edit sent messages. Click that box. This will take you to a screen where you write a message. scroll down to the bottom and you sill see several options, Click on save sent message. That should correct your problem.
dingy Posted December 10, 2013 Posted December 10, 2013 Little more detailed way to do this. Attached is a screen shot of where you need to go to set to save messages. After you click on 'User CP' in left column, In the 'Settings & Options, block, click on 'Edit Options. This will bring up screen that is in attached picture. In the Private Messaging block, click on 'Save a copy of sent messages....' Gary
Black Owl Posted December 11, 2013 Posted December 11, 2013 Don't leave us hanging. Did the suggestions help?
DarrinGT Posted December 11, 2013 Author Posted December 11, 2013 Thanks for the help guys...I wont leave you hangin... .I just have been too busy to sit down at a computer and try it out. Lots of snow and running a car lot sees to take up a lot of time....and now my plow motor just went out with 6 more inches comng today. Ill let ya know when I have a chance to check it out. Thanks again..
DarrinGT Posted December 14, 2013 Author Posted December 14, 2013 Little more detailed way to do this. Attached is a screen shot of where you need to go to set to save messages. After you click on 'User CP' in left column, In the 'Settings & Options, block, click on 'Edit Options. This will bring up screen that is in attached picture. In the Private Messaging block, click on 'Save a copy of sent messages....' Gary Just now had a chance to check into this, Gary you were correct, I had to change my setting so now the sent items will be saved. Thanks again guys for the help!
Flyinfool Posted December 15, 2013 Posted December 15, 2013 I just hope all of the problems you have are this easy to fix.
DarrinGT Posted December 16, 2013 Author Posted December 16, 2013 I just hope all of the problems you have are this easy to fix. That would be nice hu,.? Thanks!
