I can yank a set of 1st Gen plugs before you can drink a cup of coffee. Any tricks on the 2nd Gen? :think:I thought there was a thread on it but can't find. Might have been before crash.
I guess I'm going to have to be trained all over again. Anybody remember all those questions I had the 1st few years??
Take the tank off. Take the engine braces (I think that is what they are) off. Then plugs out. The front plugsvare as easy to get to as the rears once the braces come off.
Dan why change the plugs??? You won't ride it so the ones in there should last for years.:rotf::rotf::rotf::rotf:
When you change them use the iridium plugs there good for 100,000 miles but you should know that already.
Quit firing on left side sitting in garage!! It gets started regular?? I'm gonna ride it. One of these days. But you walk into a garage with Brown Sugar and the nameless one sitting there.......:whistling:
yes have the coffee and a healthy breakfast first, it took me an hour to figure out the first one, 10 minutes to change the other 3 then 1/2 hour to put everything back together.
Make sure you get the electrical plugs tight together under the tank cover. That was my only issue after.
Do irridiums come OEM? If not whats a good number/brand to go back in. I kind of figure if its got NGK in it now thats what should go back in. Right now I only have 27K on it. But will do a valve check here in the next few weeks so when I got it that far I figure good time to r&R plugs.
Ya mean the ones where everyone told you to go read the service manual..... :whistling: :)
Dan, that closet door is still closed on your leg??? Force it open, come out of that closet finally and get on the 2nd gen and put a tarp over Brown Sugar so she wont cry......
Dan,
It is NOT a 1st Gen :no-no-no:
Tires, Gas and Oil then get on and ride :Venture:
Not Tires, Gas, Oil, Plugs, Wires, Fuses, Antifreeze, CLASS etc then think about riding
:sign your welcome:
Gaurentee you it's that 87 octane with ethanol...
nuke it with Seafoam and ride the Hell out of it...
It is after all, closer to a first gen than you'd like to admit..:stirthepot:
taint no way taint no how, taint never been nuttin built even close to a 1st gen :stirthepot:
here we go again....:cool10:
I have a name...Orphan
