Karaboo Posted November 30, 2013 #1 Posted November 30, 2013 Does anyone make a replacement for the front audio cable? Mine was intermittent when I plugged in my headset, and I made it completely shot when I tried to fix it. I looked at Pinwall, but they did not have any of the cords for 1st gens. Does anyone know another place to search?
Squidley Posted November 30, 2013 #2 Posted November 30, 2013 If you can, post up a pic or a schematic and that may help out a bit. I might have one, but I need to know exactly what I'm looking for....
Wizard765 Posted November 30, 2013 #3 Posted November 30, 2013 You can get them new from Sierra MC electronics http://www.sierra-mc.com/proddetail.asp?prod=JM-YV-41
Karaboo Posted November 30, 2013 Author #4 Posted November 30, 2013 I looked at the one from Sierra, but it doesn't seem to have all the connections to hook up to the stock connectors. It does have the headset plug, but I am not sure if I could patch in the other connectors.
djh3 Posted November 30, 2013 #5 Posted November 30, 2013 Is it not just the standard 5 pin plug type? You need from the bike to your helmet?
MiCarl Posted November 30, 2013 #6 Posted November 30, 2013 I looked at the one from Sierra, but it doesn't seem to have all the connections to hook up to the stock connectors. It does have the headset plug, but I am not sure if I could patch in the other connectors. The other connector part way down your stock cable is for the attenuator in the little control box by the clutch. You can use the Sierra cable (I use one) but you lose the functionality of that little volume knob.
Karaboo Posted November 30, 2013 Author #7 Posted November 30, 2013 So if I go with the Sierra cable, all I lose is the intercom volume control? Will I still have intercom capability? Here is a better shot of the connectors.
dingy Posted November 30, 2013 #8 Posted November 30, 2013 How long is it approx.? How many pins in end? I probably have an extra. Just need to know which one you need. Gary
Karaboo Posted November 30, 2013 Author #9 Posted November 30, 2013 Cable is 36" long, with 5 pins and a junction with a 3 wire flat plug. A better picture is below.
MiCarl Posted November 30, 2013 #11 Posted November 30, 2013 So if I go with the Sierra cable, all I lose is the intercom volume control? Will I still have intercom capability? Here is a better shot of the connectors. No, not the intercom volume control. On the little grey box above the clutch reservoir is another volume control. There is also one on the passenger remote. That control will not turn the volume up, but lets each person turn down from whatever the amp/cb/intercom are set at. So if your passenger likes it loud, you crank the system up and can then turn it down a bit at the handle bar. That capability is what you lose with the Sierra cable. Since you didn't know what I meant I'd guess you never used it and won't miss it.
