So, what IS the most durable bike engine design..
I propose a brainstorming session about everyones thoughts on what engine design/designs, all things being equal (same maintenance care) - (my economics professors favorite saying), are most durable..
I have always been told that opposed cylinders by design are most durable BUT I have also been told that the V design (like Guzzi) are.. :stirthepot:
Hey,,,, its winter and lots of time to ponder... :backinmyday:
Puc
Oh yea,, this is brainstorming - all thoughts welcome :bighug:
Edited by cowpuc
forgot a word
OHHH,, and just to pick on Freebird and beat alllllllll my buddys on our site to it,,, we already know its not HD :cool10::cool10::cool10::cool10::cool10::rotf::rotf::rotf::rotf:
One with an electric motor, like ZERO bikes have. That's because the battery will always be low/dead and the motor just sits there, so the bike never wears out.:whistling::stirthepot:
-Pete, in Tacoma WA USA
I think the opposing cylinders is the best so far. BMW has had that in their line up for years. Subaru cars have the same design with opposing cylinders and they go for years to. Subaru engines are a Fuji motor the same ones the use in small aircraft. I don't know much about engines but if it says Yamaha I have just had to put gas and oil in and that's about it.I wonder about the Wankel rotary how that does.
I remember hearing about a Harley Sportster that went back and forth across Canada and the guy actually put one million miles on the original engine. That was a lot of years ago.
I am sure BMW are long lasting bikes also. But I have no specific examples to share.
Bubber
PS Happy Thanksgiving to all :missingtooth:
Bubber
Crow for thanksgiving for dinner,,, yuck...
Guest tx2sturgis
Caterpillar ...
Will go 1.6 million miles without major problems.
Sent from my AT100 using Tapatalk 4
Not sure that I have ever had an engine fail. However it is the surrounding parts.
1. Carbs
2. Stators
3. Starter Clutch Gears
4. Rear Ends
Who & What experience with engine failures do we have out there? Inquiring minds want to hear!
Personal experience with the following
Fathers then Mine 1968 CB750 235,000 miles no motor issues found out how nice a ride a Goldwing was
Fathers 1981 GL1200 248,000 miles no issues just wanted an upgrade.
Mine 1981 GL1200 175,000 miles no issues just wanted an upgrade
Fathers 1984 GL1200 125,000 miles stator problem
Fathers 1986 GL1200 148,000 miles stator problem
Mine 1987 Venture Royale 1300 125,000 miles no issues just crashed out
Uncles then Mine 1986 Kawasaki Voyager 1300 58,000 miles just did not like the ride. Not a good fit! No problems
Fathers 1991 GL1500 191,000 miles no motor issues crashed out
Fathers 1994 GL1500 145,000 miles no motor issues still running strong
Mine 2004 Midnight RSV 98,945 miles no motor issues still running strong.
Carb Floats & continuous Carb Syncs
Rear Shock
Stator & Rectifier
Valve Adjustments
This is the only bike that I have done any maintenance on other than Changing Oil & Filter & All Fluid. Brake Pads, Plugs & Tires
Seems like a pretty good run of bike history running strong.
Puc
I believe the 2005 midnight rsv is the one your talking about:rotf:
Bubber
Probably looking for the parts that fell off
The BMW designed opposed twin sure last for many decades, and still continues in some copies. I had an R 65 many years ago. Not blinding speed but ran very well with good mountain power.
:farmer:
Would be hard to beat !! About 100,000 milles between valve jobs, and about
300,000 between lower end overhauls.
Maby a new clutch every 100K also.
I remember hearing about one fellow, ( around 20 years ago this was ) had a 650 twin,
that had 3 million milles on it. Useing the above Overhaul schedule !!
Not sure where he went, but must have been just about everwhere !!
I remember back around 1968, I used to stop in at a Beemer dealer, in Van Nuys Calif, and Droolllllll over the New, " Black " 650's and (well whatever size they were) That were sitting there, which I could not afford at the time :whistling:
In 1982, I finally bought an R-1000. Ahhhh, Seatle to LA, back and forth for 10 years on that bike !!!
