Hi all I am trying to run down an electrical issue on my 2005 RSTD and I was wondering if anybody has had trouble with the starting circuit cutoff relay. On pg 8-15 of the service manual. But I cant seem to locate it to check it anybody know where it is?
Thanks
The starter relay is located on the left side of the battery box. The cable from the battery runs directly to one lug on this relay, where you will find one 30 amp fuse along with a spare. The only problem I have seen from this relay is corrosion that damaged the inner connection to the relay.
Good luck,
Rick
Thanks
I was looking at another post from ebay and saw one for the starter relay:
http://www.ebay.com/itm/Yamaha-Royal-Star-Venture-XVZ1300-STARTER-RELAY/200521814165?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D18239%26meid%3D2847569853388599392%26pid%3D100005%26prg%3D8344%26rk%3D5%26rkt%3D5%26sd%3D321251128800%26#ht_4440wt_899
Might help you understand what you are looking at?
Rick
Good luck,
Rick
Good luck,
Rick
Rick Thanks but on pg. 8-15 of the service manual it lists this as the starter relay which tests out fine. It also says there is a starting circuit cutoff relay that is what I would like to check.
