Working on my son's, 1982 - CX-500 Honda last month, ran into some spark plug problems.
I found this web site with information as to " Removeing " the RESISTOR, mounted inside the Plug cap.
I also found that One of the caps also Had and " OPEN Circuit " Inside, TOP of the Cap Assembly, and I had to Replace the cap, ( In addition to removeing the resistor )
To check this, remove the internal parts, stick rod up into assembly, to check the resistance thru the " Top " of the plug cap. One of my Honda caps, had an open
circuit in top of the assembly.
Anyway, for anybody who might be interested. Go to this link, for information, on
" Modifying " your plug caps if you want to remove the resistor, in your spark plug, caps.
(( complete with pictures, and Modificaiton information ))
Our " Venture " plug caps are basicly Identical to these HONDA Caps.
http://globalcxglvtwins.forumlaunch.net/viewtopic.php?f=6&t=84
Note: This information is from Site, referencing Honda, CX-500 bikes, but our plug caps are basicly
the same thing.
Edited by GeorgeS
