Hi all
I have a 08 Venture with a 650 Garmin which I hook to the aux jack at the cassette player.
I activated the blue tooth and I can hear the person on the other end very well but they can not hear me. Any ideas?
Guest tx2sturgis
Hi all
Are you using an actual bluetooth headset? Or are you using the bluetooth onboard the device? If so, it may be using the internal mic and not a headset mic.
Just a guess...:2cents:
AH Bluetooth the person who makes the plug and play for Bluetooth on these or any bike will be able to retire.
I have been using a Bluetooth headset adapter that runs off a 7 hour battery plugged into the AUX port. With it I can use the GPS on my cell and play MP3's through the bikes sound system.
I am also looking at a full plug and play setup that runs off the 12 volts on the bike turns on and off with the bike and also plugs into the AUX port. As far as getting the phone through the headset I'm still looking into that. A perfect setup would be 12V, Tape deck plugin through the system to the headset with full phone abilities and be under $100.00....
LOL I'll let you know if anything comes from it.....
Where do I pre-order?
I make a cable that plugs into your Mic in on the Garmin or its mount. If your garmin has that then my cable will allow you to just answer the phone and start talking. As long as you have a headset installed that is. Which most of us do.
But I think a few have already endorsed my cable in the other thread. .
Edited by BuddyRich
Quote: "I make a cable that plugs into your Mic in on the Garmin or its mount. If your garmin has that then my cable will allow you to just answer the phone and start talking. As long as you have a headset installed that is. Which most of us do.
But I think a few have already endorsed my cable in the other thread. "
The best I have found "the BuddyRich Cable":goodpost:
