Bert2006 Posted October 26, 2013 #1 Posted October 26, 2013 Lifts are on sale for $60 this week at CND Tire. Just bought the 1500lbs model similar to the Sears one. Most folks indicate that this lift will slowly lower but when I used it today I could not get it to lower slowly, it just drops. Is there any way to adjust to slow it down?
chabicheka Posted October 26, 2013 #2 Posted October 26, 2013 Instead of just stepping on the release pedal, do the pumping motion with your foot like you do with a foot pump filling air in tire...and don't push down all the way...about an inch or so only. Not sure if i expressed this properly...but it works in getting the bike down slowly...always holding on to the handle bar so it doesn't fall over. Good luck.
Sylvester Posted October 26, 2013 #3 Posted October 26, 2013 Make sure your kickstand is down fully, and always lift on the right side. This way you won't have a big surprise when you let it down.
Bert2006 Posted October 27, 2013 Author #5 Posted October 27, 2013 Read the instructions that came with it. Duhhh, if the instructions mentionned something about it I WOULD NOT BE ASKING. Thanks for your very insightfull and helpfull suggestion though...geeessss
Bert2006 Posted October 27, 2013 Author #6 Posted October 27, 2013 Instead of just stepping on the release pedal, do the pumping motion with your foot like you do with a foot pump filling air in tire...and don't push down all the way...about an inch or so only. Not sure if i expressed this properly...but it works in getting the bike down slowly...always holding on to the handle bar so it doesn't fall over. Good luck. Thanks for the advice, tried that but it releases all at once even with the slightest pressure, not even an inch. Will need to make sure I keep it balanced on tires when lowering so it does not fall on sidestand too fast. Thanks again,
syscrusher Posted October 27, 2013 #7 Posted October 27, 2013 The Larin brand one that I have is proportional. A quick jab of the release, pulling away quickly, will lower it just a little. I think thats what Chabichecka? meant, just pulse it. Mine will actually lower slowly with partial and continuous pressure but if you can't even jab and pull away then maybe your release valve is sticking open when activated.
