Venturous Randy Posted October 19, 2013 Posted October 19, 2013 Does pulling a trailer void the warranty on a 2nd gen that is still under warranty? RandyA
Black Owl Posted October 19, 2013 Posted October 19, 2013 Does pulling a trailer void the warranty on a 2nd gen that is still under warranty? RandyA What does the warranty say?
sleepy2 Posted October 19, 2013 Posted October 19, 2013 Don't know about U.S. warranty(as everything seems different between our two countries) but here in Ontario Canada my dealers told me that many people do pull trailers BUT if there is damage done that mama Yamaha might not repair under warranty as they are not made to pull trailers. Pretty sure owners manual says this also.
Condor Posted October 19, 2013 Posted October 19, 2013 For the best answer I wouldn't check with a dearler. I'd call Y directly. I remember this subject came up a few years ago, but.... I can't remember the outcome...
Trader Posted October 19, 2013 Posted October 19, 2013 might give them an "out" for clutch and rear shock issues
RSTDdog Posted October 30, 2013 Posted October 30, 2013 From the owner's Manual Consumer Information-Warranty General Exclusions c. Abnormal Strain, neglect or abuse Warranty Questions Q. Will the warranty be void or cancelled if i do not operate or maintain my new motorcycle exactly as specified inthe owner's manual? A. No. The warranty on a new motorcycle cannot be "voided" or "cancelled". However, if a particular failure is caused by operation or maintenance other than as shown in the owner's Manual, that failure may not be covered under warranty. My RSTD Owner's manual does not specifically state not to tow a trailer, however it does state don't exceed the load limit or add bulky accessories that can affect the handling steering suspension etc. The argument could be made that a trailer is a bulky accessory that affects the handling suspension and steering of the motorcycle. That being said, Yamaha fixed Zip Code Dave's engine under warranty after investigating the failure, and he pulls a trailer, has accessories, and was using non specified oil and an automotive oil filter IIRC at the time of his engine failure. Don't remember if he was pulling a trailer at the time it failed, but his trailer hitch was on it when it was getting fixed. So could they deny the claim, possibly. Will they?? In all likelyhood, probably not depending on the circumstances, type and extent of the failure.
Huggy Posted October 30, 2013 Posted October 30, 2013 I think that depends on the dealer you bought the bike from. They usually decide if the repair is going to be covered or not. Usually based on how common the failure is.
Brake Pad Posted October 30, 2013 Posted October 30, 2013 On my 07, the service department told me that my warranty, would not be valid, if I installed, my hitch. ( I told them , they were full of SH#*, they serviced my bike right up to date they received the bike at the shop, ( Not however, my purchase date) the low life scum.
Eck Posted October 30, 2013 Posted October 30, 2013 Randy, When I had my 2nd Gen RSV, I pulled a trailer.. However I kept the rear frame (brace) bar that is removed when installing the trailer hitch. I figured, if I ever had to take my 2nd Gen to the Dealer, I would just remove the trailer hitch and install that rear frame (brace) bar back in its place and then take it to the dealer.
ediddy Posted October 30, 2013 Posted October 30, 2013 I purchased my 05 RSV new. Yamaha replaced the rear end five times under warranty. The rear end was going bad every 5000 miles. When the fifth rear end was installed by a factory rep he asked me if I pulled a trailer. I told him I did not which was the truth. Nothing else was ever said.
Mike G in SC Posted October 30, 2013 Posted October 30, 2013 Both my 2006 RSTD and 2009 RSV had shocks replaced under warranty. And both had hitches on them. In fact,,,, during rear tire changes, my dealer noticed the oil on the shocks and started the warranty parts order before I had picked the bikes up. AND,,, I have a GREAT dealer. Extreme Sports Yamaha, Sumter, SC
Brake Pad Posted October 30, 2013 Posted October 30, 2013 the rear end went on my 07 @ 12K, they tried to blame the Trailer. Broward Motorsport, what a bunch of Morons
BradT Posted November 3, 2013 Posted November 3, 2013 My 08 had the rear pumpkin and the clutch basket changed under warranty at Pioneer Motorsports. Mechanic and I talked about the hitch and trailer that was it. I think the guys torque wrench was broke when I needed to remove the rear brake caliper, jeepers it was tight. Brad
