I've looked ALL over the Internet for a Front Fork Brace. Since I HAVE NOT found one, My question here is: Does anyone Make a brace for the Front Forks of my 2008 Venture??
IF SO, where can I buy it?
Thanks,
DragonStar08
why? Not required or needed to the best of my knowledge.
But to answer your question, I've never heard of one forsale. maybe someone else has other ideas.
Since the 2ndGen metal front fender is much stouter than the plastic on a 1stGen, a front fork brace isn't really neccesary, and the reason no one makes one is there wouldn't be a demand. :2cents:
I have a 2008 and the front end is smooth as silk at any speed. Going up and coming down. So like they said, maybe you need to tighten it up. Put it on a jack and test it out. Other problem could be tire wear.
