DragonStar08 Posted October 14, 2013 #1 Posted October 14, 2013 I've looked ALL over the Internet for a Front Fork Brace. Since I HAVE NOT found one, My question here is: Does anyone Make a brace for the Front Forks of my 2008 Venture?? IF SO, where can I buy it? Thanks, DragonStar08
RandyR Posted October 14, 2013 #2 Posted October 14, 2013 why? Not required or needed to the best of my knowledge. But to answer your question, I've never heard of one forsale. maybe someone else has other ideas.
M61A1MECH Posted October 14, 2013 #3 Posted October 14, 2013 If you are getting head shake and you are looking to cure it, probably need to tighten up the bearing in the steering head.
Condor Posted October 14, 2013 #4 Posted October 14, 2013 Since the 2ndGen metal front fender is much stouter than the plastic on a 1stGen, a front fork brace isn't really neccesary, and the reason no one makes one is there wouldn't be a demand.
IronMike Posted October 15, 2013 #5 Posted October 15, 2013 I have a 2008 and the front end is smooth as silk at any speed. Going up and coming down. So like they said, maybe you need to tighten it up. Put it on a jack and test it out. Other problem could be tire wear.
