Had a problem this weekend lost everything the right turn signal went out then the neutral light and then the left turn signal and the next morn no brake lights after breakfast the speedometer the mileage gage nothing left . Had it tuned in July and I think they pinched a wire and finally wore through and ground out some where under the gas tank . any one have this happen before. Ron
No checked all fusses and still good . This all was in 2 days when I stop some where and get back on the bike there would be something else out..Ron
Check the wireing harness and see if it is rubbing on the steering neck some guys have had this happen and found wires worn through from the rubbing.
Possibly an connector has pulled loose.
If any wires worn thru, there should be at least one blown fuse !!
Are you sure you checked them all ??
Had it taken in to worked on and they said a fuse and the light and everything works good. If it was just a fuse it should go all at one time instead of over 2 days Ron
