My question how can the passenger music be louder then the drivers....I have a 2000 rsv and the master volume controls front and back...the rear volume controller only lessens the volume that is set from the front .....if the wife wants the music louder the me? can you put full volume to the back helmet ? with out blasting my ears out ?
No fader with the headsets. The passenger only gets a 100% of what the front controller is set on. Example: front is set half way, rear gets 100% of the volume of front, half way. If you turn up the front to 30 on the front controller, the rear gets that much also. If you turn the front controller down to to 10, the rear gets 100% of that 10 or less if you desire. In other words, the rear can't overcome the front controller.
Plug in your headset and see if you have fader control. Fader only controls the front and rear speakers, not the headsets, that is of course, unless there was a change made to the system since 09.
