2WHEELSFORME Posted February 25, 2008 Share #1 Posted February 25, 2008 Two questions. Switched or unswitched, your preferance? Is a power supply found in the front fairing or do I have to go all the way to the battery? Link to comment Share on other sites More sharing options...
Acadieman Posted February 25, 2008 Share #2 Posted February 25, 2008 12 volt outlet found left front fairing .Thats what i will be using. Link to comment Share on other sites More sharing options...
BEER30 Posted February 26, 2008 Share #3 Posted February 26, 2008 I went straight to the battery . Why ? , cause when I stop along side of road to talk on phone (via blue-tooth) , I sometimes turn the scoot off . Or for fuel , I still want to listen to tunes (XM , MP3 , or phone) , I simply switch off the scoot but leave on accessory to not interrupt my pleasures . While refueling , I have an extra key attached to a retractable dummy-cord reel . I pull it down out of my windshield bags to unlock my gas cap instead of using ignition key . Also my caps is suspended by the cord and I have something holding my gas cap . At least if the Zumo is still powered and uninterrupted by power loss . Besides , one less thing sucking power out of the wiring harness . BEER30 Link to comment Share on other sites More sharing options...
pick Posted February 26, 2008 Share #4 Posted February 26, 2008 I spliced in a two prong trailer connector to the power cord and hooked it up to the pigtail that is attached to the battery for my battery tender. GPS is always hot and I simply unplug it if I need to hook up the tender. And it is one less thing on my harness. Link to comment Share on other sites More sharing options...
BuddyRich Posted February 26, 2008 Share #5 Posted February 26, 2008 I used the back of the cigarette lighter. That ways its switched on with the acc. Link to comment Share on other sites More sharing options...
DkKnight Posted February 26, 2008 Share #6 Posted February 26, 2008 I used the back of the cigarette lighter. That ways its switched on with the acc. Now you have to come back out here and wire mine that way! Link to comment Share on other sites More sharing options...
BigShell Posted February 26, 2008 Share #7 Posted February 26, 2008 I power mine through a 3 switch housing on top of the brake reservoir. That switch is wired from the factory to use one power input for all three toggles. I powered it from the battery through a relay. I activate the relay off the back of the cigarette lighter so the switch is hot in acc position. I feel better when I can power off the cradle when I don't have the Zumo in place. I run my Zumo and grip heaters off the switch right now. I like having the switch lose power when I shut off the ignition. That way I don't have a powered cradle exposed to the elements or have my heaters draw down the battery because I forgot to turn them off when I shut down. Link to comment Share on other sites More sharing options...
BuddyRich Posted February 26, 2008 Share #8 Posted February 26, 2008 Now you have to come back out here and wire mine that way!:rotf: I'll get right on that...:rotf: Link to comment Share on other sites More sharing options...
2WHEELSFORME Posted February 26, 2008 Author Share #9 Posted February 26, 2008 OK I used the back of the lighter because it was easy. I just unpluged the plastic connector, stuck the Zumo wires into the female side of the plug and plugged it back together pinching the new wires inside the plastic plug. My only worry now is the fuse is under the fairing making it diffucult to replace if it blows. Link to comment Share on other sites More sharing options...
Pilot Posted February 26, 2008 Share #10 Posted February 26, 2008 I used the back of the cigarette lighter. That ways its switched on with the acc. Same here, works great. Link to comment Share on other sites More sharing options...
Jercoupe Posted February 28, 2008 Share #11 Posted February 28, 2008 I used the back of the cigarette lighter. That ways its switched on with the acc. Same way as buddy rich and the big advantage i find is when i turn off the bike the zumo 550 asks if i want to continue on batt power. If you ignore it it turns itself off in a few secs. It wouldnt matter when I stop for lunch cause i pop it out of the mount but when I park the bike in my garage I leave it in. Link to comment Share on other sites More sharing options...
Mariner Fan Posted March 3, 2008 Share #12 Posted March 3, 2008 There is a little white plug under the seat by the battery. I checked it with a meter and it is switched power. Do any of you guys use this for a power supply? If so, did you simply cut the plug or is there something that can be plugged into it? I would like to use this as a switched power supply to a power panel but thought I'd check with you guys first. Link to comment Share on other sites More sharing options...
V7Goose Posted March 3, 2008 Share #13 Posted March 3, 2008 There is a little white plug under the seat by the battery. I checked it with a meter and it is switched power. Do any of you guys use this for a power supply? If so, did you simply cut the plug or is there something that can be plugged into it? I would like to use this as a switched power supply to a power panel but thought I'd check with you guys first. That white plug by the battery is powered by a little 5 amp fuse just like the front power jack (located in the right lower cowling). Probably not suitable for a "power panel". Goose Link to comment Share on other sites More sharing options...
Mariner Fan Posted March 3, 2008 Share #14 Posted March 3, 2008 That white plug by the battery is powered by a little 5 amp fuse just like the front power jack (located in the right lower cowling). Probably not suitable for a "power panel". Goose Ok, where do I tap into switched power? Link to comment Share on other sites More sharing options...
Pilot Posted March 3, 2008 Share #15 Posted March 3, 2008 Ok, where do I tap into switched power? What are you trying to power? Link to comment Share on other sites More sharing options...
V7Goose Posted March 3, 2008 Share #16 Posted March 3, 2008 Ok, where do I tap into switched power? I don't really know from back by the battery. The main fuse panel is just under the left cover, so I'd start by pulling the fuses and checking power feed to the contacts first. Unfortunately, I suspect all of those fuses are hot all the time and tie into the switched circuit later down the line. If I wasn't on this little laptop I'd look at the schematic for ya. I know you can tap switched power under the tank - that is not too far away. But you still need to be careful in identifying and selecting the specific circuit you want based on the power load you will ad to it and the risk of what happens when you pop the primary fuse to that circuit. Here is a better choice - use a standard after-market light relay and trigger it from that white plug - have full battery power supplied to your power panel through the relay. That way you risk nothing on the existing bike. Link to comment Share on other sites More sharing options...
Mariner Fan Posted March 3, 2008 Share #17 Posted March 3, 2008 Does Yamaha sell a plug so that we can use the little white plug under the seat by the battery? Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted March 3, 2008 Share #18 Posted March 3, 2008 Have you checked out these kits? http://www.easternbeaver.com/Main/Products/Fuseboxes/FB-4/fb-4.html They have a 4 and a 6 fuse kit, along with some other goodies. Link to comment Share on other sites More sharing options...
Mariner Fan Posted March 3, 2008 Share #19 Posted March 3, 2008 That looks like a nice setup. Well, I think I'll use the switched power supply to my auxiliary plug to power my XM player. I'll use the switched power supply under the seat by the battery to trigger the relay for the driving lights. I hate to have to cut the plug off but I don't see a way to use it any other way unless someone makes a plug for it. Does anyone know what this plug is for? Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted March 3, 2008 Share #20 Posted March 3, 2008 That looks like a nice setup. Well, I think I'll use the switched power supply to my auxiliary plug to power my XM player. I'll use the switched power supply under the seat by the battery to trigger the relay for the driving lights. I hate to have to cut the plug off but I don't see a way to use it any other way unless someone makes a plug for it. Does anyone know what this plug is for? I'm guessing, but I think it was originally spec'ed into the wiring harness to connect to the 'phantom' cigarette lighter power plug under the left hand side of the passenger seat. You will see a little rubber plug in that hole, instead of a power socket. Again, speculating here, but maybe Yamaha saw problems associated with that setup, and decided to remove it. I just cut the damn thing off and I'm using it to provide a voltage source for my Kisan voltage monitor. It shows me a more realistic voltage of whats in the harness, as opposed to what the battery is showing. There IS a few tenths of a volt difference. Plus, it powers down the monitor when the bike is shut down. Link to comment Share on other sites More sharing options...
Mariner Fan Posted March 5, 2008 Share #21 Posted March 5, 2008 I was wondering about that. This is the plug "cap". http://buzznet-68.vo.llnwd.net/assets/users16/marinerfan/default/Wire_plug_003--large-msg-120472057782.jpg Nice but it doesn't have the male spade pieces to make it work. I guess cutting it off is the only solution unless someone has figured out where to get a functioning plug. Link to comment Share on other sites More sharing options...
Pilot Posted March 5, 2008 Share #22 Posted March 5, 2008 If you use a snap connector you won't have to cut the plug off. Any automotive store will have them. Link to comment Share on other sites More sharing options...
