TobyRSTD Posted October 9, 2013 #1 Posted October 9, 2013 Just wondering if the tranny in my 05rstd is lubed with engine oil or if I need to change gear lube in it and how to drain and fill?
Freebird Posted October 9, 2013 #2 Posted October 9, 2013 Lubed with engine oil. That is why it is important to make sure that whatever oil you choose to use does NOT have the energy conserving label on it. It can cause your clutch to slip.
Snaggletooth Posted October 9, 2013 #3 Posted October 9, 2013 Tranny and motor all the same. They share the same case. From my Droid wherever I may happen to be at any given moment.
TobyRSTD Posted October 9, 2013 Author #4 Posted October 9, 2013 Hey thanks guys, Saw a fill plug with straight screw by oil fill? and read about bottom screw on the middle drive cover, and made me wonder.
