Seaking Posted October 7, 2013 #3 Posted October 7, 2013 I presume they need a tightening, yes? If I may, try this bounce test with the plastic cover removed from the top of the tank so that the steering can go all the way to the stops, and see if it bounces back. Additionally, if you're able to raise the bike on a solid jack and can do the push pull test on the front wheel to see if you can feel any knocking, it may give you a better indication for looseness.
