The PO of my bike put a button on the ignition cowling. Nobody at the dealership bothered to ask him it's purpose.
I took off the right lower fairing a few weeks ago and came across a zip-lock baggie with a couple circuit boards taped to the fairing.
Well, today I thought I would try to figure out what was up.
... came up with nothing and thought maybe an electronics guru or 3 could offer suggestions.
There are 4 wires coming from these two boards. The two blue ones go to the button on the ignition cowl and the red and green are hanging loose under the seat ( for connection to battery power )
I don't know how to attach bigger pictures, but I have typed in every string of numbers to google and have come up with nothing.
Any help or thoughts would be appreciated.
Bob
Its a garage door opener the chip on the prefbord reduces the voltage to a level uadable for the opener youcan tell where they soldered rhe leads to the batyery contacts
Edited by etcswjoe
Even if it doesn't work on your door you could buy the keychain remote for your door and wire it in instead of the larger of the two boards. The red and green leads that are attached to it are supplying coin battery level power for the board and the blue leads are coming from your dash mounted switch and are making one of the connections for the pushbutton switches on the remote. Just insert your own remote and you're good to go.
I do think that I recognize the remote though and it is for the previous generation of Chamberlain/LiftMaster/Craftsman garage door openers and the remote will work with (nearly) anything from those distributors except for the very most recent door openers, or maybe really old ones that are before the rolling codes technology.
It's a 970 or 956.
Was replaced by the 890 MAX, which works with the most recent openers too.
Definitely try programming it in for use with your door if you have a lift from any of those companies.
Yup, Joe is right on. The first board has a voltage regulator to reduce the voltage to the opener voltage. The other board is the opener but needs some kind of push button to activate it. Chuck the green board, the perf board could be used to power a new remote...
