Zollars3265 Posted September 27, 2013 #1 Posted September 27, 2013 Ok, I want to buy a connector to connect to the accessory wire under the seat. Anyone know what type or size or what its called? Oh its a 2008 RSV
M61A1MECH Posted September 27, 2013 #2 Posted September 27, 2013 (edited) Here is a link to a tech article on one way to use it. http://www.venturerider.org/forum/showthread.php?t=38187 Here is link to where you can buy the contacts and wire seals that will fit that connector. http://www.cycleterminal.com/mt-series-090.html Also here is cut and paste from the web site so you know exactly which one to get. Edited September 27, 2013 by M61A1MECH
csdexter Posted September 28, 2013 #4 Posted September 28, 2013 You may note that the other half of the connector is there from the factory. It's plugged with blind plugs where the wires would exit -- so you need two terminals and two wire plugs to complete your hook-up. If for some reason it's not there (or you'd like to get a new connector set just in case), these guys have a good selection: http://www.easternbeaver.com/Main/Elec__Products/Connectors/Sealed/SM-MT/sm-mt.html
etcswjoe Posted September 28, 2013 #5 Posted September 28, 2013 I just cut the connector off and soldered directly to it.
XV1100SE Posted September 28, 2013 #6 Posted September 28, 2013 Another option might be to cut off the plug that is there and use one that you can easily find at a store.
