Best Place to Tie in?
RevJonG
I have ordered a Custom Dynamics TF115ARC.
I need to tie into the brake light, running light, and turn signal wires. What is the easiest way to do that? Is there a "plug and play harness" available? If not where is the best place and best method to gain access to those wires?
Thank You!
RevJonG
:fingers-crossed-emo
I installed mine under the seat. The plug that goes through the back of the seat pan and through the fender has all the wires you need. I spliced in on the frame side (not the fender side) of the plug. That way I could remove the fender with out cutting back into it. I remove the fender when pulling the rear tire. The installation is very simple. Just make sure you check the color code of the wires. I attached the load eq under the seat too. I just zip tied it to the seat rail and attached the control unit to the seat pan by drilling 4 small holes to run zip ties through. I'll try to send pictures when I get home from work.
