I went and disconnected the cb and the air pump computer to fix the crack I had on the plastic. When I put it back together for some reason I know have a tick in my radio from the engine!!!
Drives me crazy!
Please help me , I have a 86 Venture Royale .:bowdown:
Clean all the contacts to the CB and make sure they are all tight. I would suspect the real source is the "Y" adapter for the antenna has a dirty ground, especially the one that goes from the splitter to the radio. Make sure the splitter has a good clean ground as well...
The Y adapter is the box that is mounted on the end of the CB. It has a square frame mount. Just follow the CB antenna jack from the CB back to a box that has 3 coax wires on it, one from the antenna, one to the CB, and one to the FM tuner...
Bob you'll not believe what it was!! I took it apart to check like you said and on the very bottom of the cb is a cable that has like 5pins in it and it wasn't plugged in....:178::Avatars_Gee_George:
