dfwthompson Posted September 5, 2013 Posted September 5, 2013 Guys....cannot tell you how much this site has helped me not to mention the money I have saved. MANY THANKS to all of you!! I'm having an issue with #2 on my '83 V std not closing completely and not having any luck finding someone who has experienced the same problem. Thought I read somewhere in the svc manual about a barrel adj but can't find it or maybe dreamed it one. After trying every adjustment at grip and carb I noticed when I crank back on the throttle a barrel on the cable compresses a spring on the throttle stop at the top of #1 and the throttle plate seats as it should. Is there an adjustment I'm not seeing... either on the spring or the barrel? Thanks again!! jt
Prairiehammer Posted September 5, 2013 Posted September 5, 2013 I suspect that your carb synchronization is off. If #2 is the ONLY throttle plate not fully closed and the rest ARE fully closed, back off the other synch screws until loose and redo the carb synchronization. Number 2 carb plate is adjusted with the idle screw knob and then the other cylinders are matched to number 2.
dfwthompson Posted September 5, 2013 Author Posted September 5, 2013 Thanks Kevin....all sync screws backed out to loose. #1 and #3 fully close, #4 throttle plate looks like #2 when throttle is backed off with a little pressure. Plates moves just a hair to fully seat. Will sync #1 and #2 by ear first before attaching the carbtune. Will let you know how the new diaphragms work or I'll be asking for more help?? I ordered them a few yrs ago. I guess it's about time. Thanks again for your response. jt
dingy Posted September 5, 2013 Posted September 5, 2013 (edited) Thanks Kevin....all sync screws backed out to loose. #1 and #3 fully close, #4 throttle plate looks like #2 when throttle is backed off with a little pressure. Plates moves just a hair to fully seat. Will sync #1 and #2 by ear first before attaching the carbtune. Will let you know how the new diaphragms work or I'll be asking for more help?? I ordered them a few yrs ago. I guess it's about time. Thanks again for your response. jt #2 throttle plate is adjusted by the idle setting screw. No 'sync' screw for this carb. Set #2 closed then match other 3 to it. I see Prarriehammer already mentioned this after I rerad post, hate when I double up on someones already correct answer. Gary Edited September 5, 2013 by dingy Already answered, drat!!!
dfwthompson Posted September 6, 2013 Author Posted September 6, 2013 Thanks Gary...installing new diaphragms now. Will post and advise how things progressed with the sync. jt
