mrsteve Posted September 5, 2013 #1 Posted September 5, 2013 I can only change the volume on the radio when riding, can't even make the radio or cb turn off. I have to be stopped or nothing but the volume works. What am I missing, or probably doing wrong? It worked fine up untill a few days ago.
etcswjoe Posted September 5, 2013 #2 Posted September 5, 2013 Sounds like you need to clean and put some dielectric grease on the connections behind the fairing, this is usally the culprit for most RSV audio issues.
bongobobny Posted September 5, 2013 #3 Posted September 5, 2013 Yup! Time to split the fairing and clean all the connectors for the audio system and install dielectric grease to keep the moisture out...
mrsteve Posted September 6, 2013 Author #4 Posted September 6, 2013 Thanks guys, that's kinda what I thought since I did alot of rain riding last weekend. Guess what I'm doing this weekend. Steve
MikeWa Posted September 6, 2013 #5 Posted September 6, 2013 Thanks guys, that's kinda what I thought since I did alot of rain riding last weekend. Guess what I'm doing this weekend. Steve In addition to cleaning connections you might also have gotton some water in the controller. Mike
dacheedah Posted September 6, 2013 #6 Posted September 6, 2013 anything green cleaned up , dielectric grease especially around the outside of the boots and two white connectors
