Could be plastic beginning to rub from vibration. Try lightly pressing on different panels/pieces when you hear the sound. If it quits chirping, there you are..........
-Pete, in Tacoma WA USA
Edited by Peder_y2k
spellcheck
Did you just turn 55?
DO you get a chirping sound all the time or only at a certain time of day?
What are you doing when you hear the chirping sound?
It absolutely is NOT normal.
  SARNA66 said:
Is this normal?
YES!! Around that speed it is very normal on most 1st Gens.. something about square cut gears or whatnot.. mine is like that as well... I put a little motorkote in every third oil change and it lessens it quite a bit.. at lower speeds and higher speeds it goes away completely.
