cdance3439 Posted September 3, 2013 #1 Posted September 3, 2013 My low beam is now very dim. To the point I can not use it when I ride. Does anyone know what is wrong and some fixes. High beam is fine.
IronMike Posted September 3, 2013 #2 Posted September 3, 2013 Halogen lights degrade over time and should be replaced. http://www.lawnsite.com/archive/index.php/t-366134.html http://en.wikipedia.org/wiki/Electric_light
Flyinfool Posted September 3, 2013 #3 Posted September 3, 2013 Clean the contacts in the dimmer switch.
dingy Posted September 4, 2013 #4 Posted September 4, 2013 Clean the contacts in the dimmer switch. This is link to cleaning switch. http://www.venturerider.org/forum/sh...ad.php?t=43025 This will help us know what bike you have when you ask for help. http://www.venturerider.org/forum/sh...ad.php?t=58880 Gary
cdance3439 Posted September 4, 2013 Author #5 Posted September 4, 2013 Thanks ok I have to ask what is a, 03 RSV Hybrid. Chris
Venturous Randy Posted September 4, 2013 #6 Posted September 4, 2013 My low beam is now very dim. To the point I can not use it when I ride. Does anyone know what is wrong and some fixes. High beam is fine. You need to remove the CMS, the readout in the middle of the dash, and take it apart and resolder the connections. There is a how to in the 1st gen tech section. http://www.venturerider.org/forum/showthread.php?t=33328 RandyA
cdance3439 Posted September 4, 2013 Author #7 Posted September 4, 2013 Was your low beam just barely on but high beam was fine. It was working fine then all of the sudden dim. Changed the bulb still did the same thing. Thanks for your help
Venturous Randy Posted September 4, 2013 #8 Posted September 4, 2013 Was your low beam just barely on but high beam was fine. It was working fine then all of the sudden dim. Changed the bulb still did the same thing. Thanks for your help Yep, this is typical of a cold solder joint in the CMU. RandyA
dingy Posted September 4, 2013 #9 Posted September 4, 2013 Thanks ok I have to ask what is a, 03 RSV Hybrid. Chris Not much yet, but it will be. 2003 RSV starting point, VMax configured 1300 motor, wheels & final drive. 1st gen front end. http://www.venturerider.org/forum/showthread.php?t=74692 Gary
