for my '86 VR......
-- and the tough one: stock needles and main jets (to replace the non- stock ones on there now) I know I will probably need a set of carbs to get the needles, so they dont need to be pretty. I would just buy a nice set and be done with it, but thats not in the budget.
Anyone interested in some custom high flow intakes??????????:whistling:
Edited by venture83_98
updated list
Are the intake manifolds on an 84 the same for his 86 ? :confused24:
83's are different. I have a set not sure what from. I think 83 had nipple on it for Boost??Have to do some looking.
I just took a set off of one of my 84 parts bikes. They look the same but... somebody will have to make the final decision. You can have them if you want them. ...if they will work..
I also have a set of carbs off of one 84 that I have had trouble getting the sliders out of, but the slide needles are OK. Which are the main jets ?
PAJ1 or Pilot Air Jet 1
PAJ2 ?
The Main Jet Air Bleed. ?:confused24:
The 1200 and 1300 have different size jets , and the needles have different numbers also. So, I would needs parts from a 1300.
Did you want the manifolds ?
Someone offered a set up before you said you had them also. Thanks for checking.
All I need now are the needles and some jets. Any ideas? The needles are listed as discontinued/ unavailable.
