Bert2006 Posted August 23, 2013 Posted August 23, 2013 Added about 1\4 bottle of seafoam to a full thank of gas. Is that enough or too much. Plan on doing so for the next few months prior to storing for winter. Thanks in advance for any advice or wisdom you can share on this.
Freebird Posted August 24, 2013 Posted August 24, 2013 I agree. That will be fine for running and cleaning it out before winter. I never actually do that though. I add one full can to a full tank of gas before parking it for the winter. Have done that for the past 10 years and it has worked well for me. I ride it to the gas station about 2 miles away, fill it up and add the Seafoam there and then ride it home. I figure that gets it into the carbs, lines, etc.
Bert2006 Posted August 24, 2013 Author Posted August 24, 2013 Great thanks guy's. Alway's can count on you for swift responses.
Trader Posted August 24, 2013 Posted August 24, 2013 But....when you fill it for the last time before winter (or anytime it's going to sit for a few weeks), it is still best to use a NON ETHANOL fuel. Up here it is only the premium that is non-ethanol. I burn the regular most times with a few ounces of sea foam every 2nd or 3rd tank.
Bert2006 Posted August 24, 2013 Author Posted August 24, 2013 But....when you fill it for the last time before winter (or anytime it's going to sit for a few weeks), it is still best to use a NON ETHANOL fuel. Up here it is only the premium that is non-ethanol. I burn the regular most times with a few ounces of sea foam every 2nd or 3rd tank. I do burn premium all of the time and stay away from regular or mid-grade to avoid ethanol. Using seafoam now with the intent to clean out carbs or prevent other problems. I bought this bike this year and it had 31000 miles on it. I have put 5000 miles on it this summer. Previous owner lefts me no records on maintenance and was probably runing regular fuel with 10% ethanol. Will also probably change fuel filter this fall and have new plugs put in and carbs syncronized next spring. Bike has ben running fine but noticed that it is sluggish on first start up in morning with sticky choke. Hope seafoam will help with that.
bongobobny Posted August 24, 2013 Posted August 24, 2013 I use 1/2 can for 1 tank of gas. For winter I use Stabul...
Bert2006 Posted August 24, 2013 Author Posted August 24, 2013 Ok. Ran bike today for the first time after adding seafoam and i got mild backfire on startup which has never happenned before. Also normally have to start on full choke and only needed half choke. Seems to have more power also on acceleration. Is it my imagination or does this stuff really work that fast and well. I added the seafoam yesterday and let it sit overnight.
Flyinfool Posted August 25, 2013 Posted August 25, 2013 Overnight is enough time to start to make a difference.
dacheedah Posted August 25, 2013 Posted August 25, 2013 A 24 hr soak is good, short rides in town let the idle jets get some love. Sent from my iPhone using Tapatalk
bongobobny Posted August 25, 2013 Posted August 25, 2013 Plan on replacing your plugs, the seafoam is known for loosening up so much crud it can eventually foul the plugs...
