I took the rear axle gear case off the bike to check and re grease and I could not get the da*m case off the rim! I tired for an hour to get it to lift off! Then my wife came out to see what I was doing so I showed her what I was doing and said I can't get it apart. Sooooo she looks at it and PUSHES on the wheel with her finger and it FALLS off the case!!!!:whistling: Well at least she got it apart for me!!!!!:backinmyday:
:mytruck1:
Ya I figure I should because if I don't she WILL when she meets the other members.:whistling: So I may as well get it over with now.:confused24:
:mytruck1:
Step away from the bike...hand the keys to your wife...give her your forum password and help her with a screen name. You just got replaced.... :rasberry:
dacheedah telling you guys about it is bad enough!! I'm sure not going to post pictures of her taking over!:whistling:
And KIC I am starting to feel like you may be right. I think I'll go to my room and cry now.:crying:
:mytruck1:
I had a similar issue. One washer slides OVER the axle and one only fits as far as the shoulder at the bottom of the threads.
Played with that thing for about an hour and just couldn't get the axle back in....
Finally my wife came out to see how I was doing....and together WE figured that out.:whistling:
  Mike G in SC said:
Well, you show her,,,, the next time she asks you to open a jar of pickles!
Ya Mike I got her BEAT in that department!:backinmyday: I'd like to see her open one!!:backinmyday:
:mytruck1:
