Where is the rear brake reservoir located?
Right side (as you are sitting on it). Remove the r/h side cover. The rear brake master cylinder is just above the on-off-reserve gas cock. Square looking thing.
If you are going to bleed your bakes, remember that the rear and the left front caliper are linked. Also, do not fill your reservoir to the top as it will cause the brakes to lock up as the brake fluid gets hot and expands. It is a good thing to have an 8mm wrench with you when you take a ride after bleeding your brakes.
RandyA
