star4772 Posted August 14, 2013 #1 Posted August 14, 2013 Put coolant in reservoir then put bike up right to check and little over the full mark should this be ok? On side stand shows just below full mark and level shows little over full. Also replaced battery because one terminal on + side was cracked because someone put to long of screw in it so to be safe I replaced the battery.
darthandy Posted August 14, 2013 #2 Posted August 14, 2013 Shouldn't be a problem. If you did this when the bike was cold, then it's theoretically possible that if the engine gets really hot and the coolant expands a lot, you could wind up with some overflow on the ground. A bit messy but OK otherwise. Andy
star4772 Posted August 14, 2013 Author #3 Posted August 14, 2013 Shouldn't be a problem. If you did this when the bike was cold, then it's theoretically possible that if the engine gets really hot and the coolant expands a lot, you could wind up with some overflow on the ground. A bit messy but OK otherwise. Andy No did everything cold so I should be good.
