Nemo Posted August 11, 2013 #1 Posted August 11, 2013 I thought it was an oil leak, but it's brake fluid. The hose to the clutch, or something else, is leaking. I had to fill the reservoir and bleed the clutch line. Where do I look to inspect the lower connection on this 2nd gen RSV? Help needed again.
Trader Posted August 11, 2013 #2 Posted August 11, 2013 if it seems to be down just behind the shifter, it could you your clutch slave cyl.
M61A1MECH Posted August 11, 2013 #3 Posted August 11, 2013 On the left side just forward of the rear exhaust pipe and above the cover you wanted to take off to inspect for the leak in your other post you will find a rubber flap, that is where the bleeder is, is that where you bled the clutch? Should be able to trace the lines from there. I just looked at mine, on the left just forward of the air box and then again just in front of the front cyclinder there are junctions where the clutch line converts from rubber hose to steel tubing, that tubing incased in a rubber protective cover goes down and passes under the motor and then turns straight up to where the slave piston is and the bleeder is. If you take the rubber door off where the bleeder is you can see down in there a bit, but there not much to look at, I bet that slave piston is not fun to get out. Good luck, keep us posted on what you find.
