CFox0045 Posted August 4, 2013 #1 Posted August 4, 2013 Have a question regarding the Mustang seat with back rest, just acquired one used, and the back rest was removed. Was wondering if this was removable or not as the base of the back rest has notches in it for some reason and feels loose in the seat when installed. Thanks, Chris Sent from my DROID RAZR using Tapatalk 4 Beta
rickardracing Posted August 4, 2013 #2 Posted August 4, 2013 My wife has one on her Shadow. Backrest is removable. Just pull it out. Maybe an adjustment inside the seat, contact the manufacturer.
TDbiker Posted August 5, 2013 #3 Posted August 5, 2013 I have the mustang seat with backrest. The backrest post just slides into the slot in the driver seat. Mine didn't want to hold it's position so I contacted Mustang. Here's their response: There is an adjustment setscrew inside of the seat. Turn it clockwise to tighten the backrest’s height adjustment. You will need another person to help. They will have to push the seat foam down so you can gain access to the screw. See the attached information for its location. Attached is the picture. Good luck.
CFox0045 Posted August 6, 2013 Author #4 Posted August 6, 2013 Found the problem. Working now. Thanks for the help Sent from my DROID RAZR using Tapatalk 4 Beta
